I'm not aware of any way to reprogram that particular thermostat. Here are the instructions to read the actual temperature the unit is showing.
If you press the sleep button for 5 seconds it will show the actual temperature reading. Remember that this is the temperature at the display unit and may not reflect every area of the coach.
2. Temperature setting (continued) To display the room temperature, press SLEEP button for 5sec or longer. While this button is depressed, the room temperature is displayed until the key is released. Given the lack of display characters - if the control is displaying temperature in Fahrenheit, temperatures of 100-109°F will be displayed as A0 –A9, temperatures between 110-119°F will be displayed as B0-B9, temperatures between 120-129°F will be displayed as C0-C9, temperatures between 130-139°F will be displayed as D0-D9, temperatures between 140-149°F will be displayed as E0-E9, and temperatures between 150-159°F will be displayed as F0-F9. Temperatures are displayed normally in degrees Centigrade.
Tom and Karen
Las Vegas, NV
2019 Forest River Georgetown 34H5
