Old 05-26-2016, 06:10 PM   #11
chrisbailey13's Avatar
Originally Posted by Dijoeboss View Post
I would think there has to be something in the system to change from generator to shore power even though there is a 50 amp plug box in your Rv
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
I used to have the same set up in my old Georgetown.
1. the Generator supplies power to the plug, so when you plug into it you are powering the entire RV via the power cord.
2. when you have shore power, you unplug from the outlet in the power area and plug into the pedestal. and the RV is powered via the power cord. if you happen to turn on the generator it isn't going to change anything, because the cord is not plugged into the outlet.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 05-26-2016, 06:15 PM   #12
Dijoeboss, mine has done the same thing
It has kicked off when I am driving show, backing up and hot a small bump
It does not switch back on until I turn off the ac's.
I think mine is the furion brand
The solenoids on the inside are the open air type.
Doesn't happen much so I have lived with it
If you find a solution please post it.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 05-26-2016, 06:31 PM   #13
I should also point out that mine does the same thing on my current RV when I run both A/C's and the HW heater is set for Electric. it is not consistent, but with the HW heater, 2 A/C's, and fridge I think there is just too much load for the transfer switch.
But I have noticed if I switch the HW heater to propane, the problem seems to go away.
Old 05-26-2016, 06:57 PM   #14
Dijoeboss's Avatar
I had generator running, front a/c unit roof mount, refrigerator, and was rolling from a stop, no more than 5 mph, and it tripped out. When your trying to drive from Oklahoma to Florida, it gets very old having to shut off a/c units at random to let the transfer switch re-engage and then turn them back on.
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 05-26-2016, 07:04 PM   #15
Dijoeboss's Avatar
Originally Posted by Cornelius View Post
My Georgetown does not have a transfer switch for the generator. Instead, there is a 50 amp campground outlet installed in the cord storage compartment that is connected to the generator. When I leave a campground, the big power cord is simply plugged into the outlet. If I want to use the generator, it's ready to go. Works every time...
This is something I would consider! Did this set-up come factory like this?
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 05-26-2016, 07:14 PM   #16
Moorio's Avatar
transfer switch
Mine did not come with one. Now if something goes wrong i know its not the transfer switch. I had one fail on my last motorhome. You know what they say "One more thing to go wrong".
2011 Gergetown 378 TS XL on a Workhorse W22 chassis
Toad is a 2014 Chevy Cruze RS
Moorio is offline   Reply With Quote
Old 05-27-2016, 11:49 AM   #17
Dijoeboss's Avatar
Name:	ImageUploadedByForest River Forums1464367759.496570.jpg
ID:	109230 on site livin the dream!
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 05-30-2016, 04:34 PM   #18
Dijoeboss's Avatar
Is there any kind of risk if I take out the transfer switch altogether and just wire in a 50 amp receptacle and make plug ends on the generator cord and shore power cord?? Like what was kinda mentioned above.... I do not have an autos tart generator, thus no need for an auto transfer switch.....
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 05-30-2016, 04:40 PM   #19
Iggy's Avatar
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
As long as you know what you have to do before hand.
Separate both power sources and when wiring in the new plug get the color code and wires right.
Old 05-30-2016, 04:45 PM   #20
Dijoeboss's Avatar
Guess my main concern is the transfer switch itself is not a breaker, or safety device, I understand it can kick out, but the 50 amp breakers inside coach are there for safety and the breakers on the generator are there for safety.
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
transfer switch
