Old 09-28-2015, 10:45 PM   #1
Automatic Transfer Switch
When plugged into shore power, we are getting no power to the coach. I have observed the automatic transfer switch is not pulling in when the park breaker is closed. I can press on the switch and get it to supply power but it will not stay engaged. The generator side works fine. All connections seem good to the shore power side of the ATS as does the voltage coming from the park plug. Any thoughts?
2014 GT 378 XL
2005 Jeep Wrangler TJ
jeffv003 is offline   Reply With Quote
Old 09-29-2015, 06:57 AM   #2
chrisbailey13's Avatar
2014 GT 378 XL
I had the opposite problem when I first got my coach. I had power on shore power, but not the generator, the Dealer had to replace the ATS.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 09-29-2015, 07:51 AM   #3
Head Rambler
Has it ever worked for you?
Sounds like you may have a bad relay coil.
Have you checked voltage at the coil terminals?
Gotta go campin!
Old 09-29-2015, 11:06 AM   #4
Iggy's Avatar
Jeff
It sounds like the contactor coil is bad or the contacts relay coils is bad.
It may also be that you have a wire that may have been loose or off the terminal strip.
These things are very simple and most times the relay is bad.
Here is a simplified diagram that shows how things work.
The relays on my diagram that will stop it from working is the K1 or K2 relay or the thermal overloads are tripped and need resetting.
What brand is yours as FR has a few manufacturers they use.
Old 09-29-2015, 12:05 PM   #5
It was a bad ATS. Thanks to Texas RV Supply in San Antonio for squeezing me in this morning when two other Extended Warranty recommended RV shops said come back in three weeks. Very nice folks! Port Aransas here we come.
2014 GT 378 XL
2005 Jeep Wrangler Unlimited
Old 09-29-2015, 01:37 PM   #6
Iggy's Avatar
2014 GT 378 XL
So was it replaced under warranty?
Old 09-29-2015, 01:40 PM   #7
Extended warranty. Paid dedictible.
2014 GT 378 XL
Old 09-30-2015, 08:16 PM   #8
it was a furrion model ?
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 09-30-2015, 09:56 PM   #9
Yes, Furrion.
2014 GT 378 XL
transfer switch
