Old 05-02-2016, 10:50 AM   #1
Matt Majeed's Avatar
Awning
silly question, how do you tilt the Awning to keep the rain water from collecting at the middle? We own a 2016 Georgetown 351DS.
Your help is appreciated.
Thanks,
Matt
Matt Majeed is offline   Reply With Quote
Old 05-02-2016, 10:52 AM   #2
On my vengeance you can just grab one of the support arms and pull it down a bit. You can adjust it on either side. Mine is a power awning so it should be about the same as yours.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is online now   Reply With Quote
Old 05-02-2016, 11:01 AM   #3
I'll try that this afternoon. Thanks...
Old 05-02-2016, 11:14 AM   #4
Might be similar to this. Pull at the "knee".
I googled your model Georgetown and the pics with awnings looks like mine so it should adjust the same. Very nice rig btw.
2016 Vengeance 320A
Old 05-02-2016, 11:17 AM   #5
Flybob's Avatar
There should be a knob on the awning arm you can tighten after you pull down on the end you want to lower. IMPORTANT: be sure you loosen the knob before your roll the awning up. I attach one of these to the knob whenever I tighten it so I do not forget to loosen the knob before rolling up the awning. You can find them on ebay.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-02-2016, 11:23 AM   #6
My 2012 non powered awning had a knob but my 2016 power awning does not have one. Makes me wonder how long before I will wish it had a knob to keep the awning in place...
2016 Vengeance 320A
Old 05-02-2016, 11:31 AM   #7
Mine did have a knob, I loosened it but it still wont budge! I wonder if I need to spray it to loosen the connection between the plastic and the metal rail!
Other than the awning, we really have not had any major issues with it. Oh, apart from the fact that the brakes and connections were so dry that I have to grease the connections and brakes.
Thanks,
Matt
awning
