Old 06-04-2019, 05:01 PM   #1
Sbryant's Avatar
Awning
We have a 2014 360 XL. The awning is pieced together about 8-12 inches away from top thus making a seam. Everytime is rains, water leaks thru the seam. I cannot believe that my awning is the only one in the world seamed together. So, we bought some awning tape thinking we could apply it and waterproof the awning. Anybody done this? How is a person supposed to hold the material to apply the tape when it’s 12 ft up?
Sbryant is offline   Reply With Quote
Old 06-05-2019, 10:29 PM   #2
BirdeeGirl's Avatar
Tape the top of the awning from the roof of the RV?
BirdeeGirl is offline   Reply With Quote
Old 06-05-2019, 10:31 PM   #3
Sbryant's Avatar
Thanks for the idea. Had not thought about that.
Old 06-05-2019, 10:34 PM   #4
dannyabear's Avatar
It is leaking from the holes for the stiching. go to Walmart or Academy sport and buy a bottle of seam sealer (used for tents) and spread a thin coat of it on the seam from the top
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 06-05-2019, 10:58 PM   #5
Sbryant's Avatar
Thanks for your suggestion.
Old 06-09-2019, 08:33 PM   #6
Frank DeFeo's Avatar
Awning
I have a 2017 369xl and mine does the exact same thing. Leaks where the 2 pieces are stitched together 8/10” down from roof.
Frank DeFeo is offline   Reply With Quote
Old 06-09-2019, 08:35 PM   #7
Sbryant's Avatar
Have you tried anything to stop the leaking?
Old 06-09-2019, 09:22 PM   #8
If your awning is like mine it extends straight out from unit with no pitch. Thus water collects on top and if not enough to auto dump it just sits there and drips through stitching. So now what I do is when we set up I simply drop front of awning manually down several inches so water doesn’t collect.
Old 06-10-2019, 10:05 AM   #9
NXR
If you have the Solera awnings, you can just grab the awning arm and pull it down to angle it on one or both ends. There's a sticker on ours to that effect. When it retracts it just straightens itself up.
Ray
NXR is offline   Reply With Quote
Old 06-10-2019, 02:31 PM   #10
Ray, thanks for the suggestion. Will check out my awning brand.
awning
