Old 07-29-2015, 04:03 PM   #1
Awning - can angle be adjusted??
Does anyone know if the lower articulating support arms on the Georgetown awning (we have a 2014 329 DS) are designed to be adjusted? They each have a knob which appears appears to allow adjustment so arms can be pushed in and out but my arms won't push in. It may be as simple as a little spray of WD40, but I don't want to force them and damage them.
CindyB
2014 Georgetown 329DS
CindyB is offline   Reply With Quote
Old 07-29-2015, 04:09 PM   #2
I always have the rear arm pulled in at that knob all the way. This tilts the awning to the back of the coach and drains the rain off. It can be tough pulling that arm in, i have to get onto a step stool to get up to the right height to pull it in and lock it. You can pull both arms in which will lower the awning if you wanted. It is at a high angle partly i think because of the entrance door possible rubbing against the underside of the open awning.
DuncanM
2014 Georgetown 335DS
Lincoln MKX toad
DuncanM is offline   Reply With Quote
Old 07-29-2015, 04:14 PM   #3
Thanks Duncan, that tells me those arms are designed to go in - why else would the knobs be there. I'll try some WD40 and get up on a step stool with a rubber mallet and pound a little, or a lot
CindyB
Old 07-29-2015, 04:20 PM   #4
Ford Idaho's Avatar
They should move free by hand, are the knobs loose?
If not then loosen them.
Old 07-30-2015, 12:06 PM   #5
Send a message via Yahoo to carluv
I installed a pull strap on mine like used on non power awnings, so I can pull it down and my wife tightens the knob.
carluv is offline   Reply With Quote
Old 07-30-2015, 12:36 PM   #6
I Break Everything
mikel68's Avatar
We have 351DS and found the same issue. It's a bit of a pain to get them angled down. Before this I had the manual one which was pretty easy. Now I need a step stool, just one more thing to pack.
2015 Georgetown Forest River 351DS MH
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 07-30-2015, 02:02 PM   #7
mike.t's Avatar
May help.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-30-2015, 08:31 PM   #8
GABoy's Avatar
Get one of these at cw. Saves a headache!
Name:	ImageUploadedByForest River Forums1438306218.235503.jpg
ID:	84614Click image for larger version
Name:	ImageUploadedByForest River Forums1438306249.996308.jpg
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is online now   Reply With Quote
Old 07-30-2015, 08:54 PM   #9
mike.t's Avatar
Attachment 84614Attachment 84615
May be looking at something else but isn't that the manual rod for the awning?
Oh is that to pull the arm down? DUH
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 07-30-2015, 09:02 PM   #10
bubbles's Avatar
Why don't you make the adjustment before the awning is fully deployed. I make mine with the awning just barely deployed when I can still reach the slider adjustment. I reverse the procedure when stowing.
awning
