I did some checking on another forum. That 3 hole bracket is not standard equipment, The guy made it. Basically, its does the same thing as extending the links by 3 inches.
You will have a "Z" bracket at the top, you just won't have three holes.
You also have a "Z" at the bottom. You won't be able to re-use the bottom one, it will hit the link, leave the bottom on off, not a big deal.
I would recommend longer links, this improves the geometry a lot.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
