07-31-2013, 11:42 AM
Back up camera
Went down last night to get our 2012 378 packed for Goshen to head to the big rally and my monitor is not working it has power but no picture on monitor backing or turning. Any clues I tried to troubleshoot but no luck
07-31-2013, 11:56 AM
CLASS "A" Senior Member
Did you try turning the Contrast or Brightness Knobs? Day/Night Button? If turned down all the way at least on my black and white monitor there's only a blank screen.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
07-31-2013, 12:07 PM
On the new monitors there is a menu button to adjust contrast but screen is so dark can't see anything to adjust.
07-31-2013, 12:19 PM
Had the same issue
Unless the adjustment worked for you. On ours (351 DS) we had to have a the right side camera replaced.....seems to have fixed the problem IAW the dealership, we pick it up Saturday, so we'll see
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
07-31-2013, 12:24 PM
I hope to get forest river to take a look at it at the rally
07-31-2013, 12:58 PM
Good luck on your trip, hope it's an easy fix
'Pa Pa's Palace'
07-31-2013, 03:33 PM
My 2013 350 does the same from time to time. I have it on the list for FR to replace. It seemed to be a timing issue. If I turn the key on to start the engine, I leave on Accessory until the screen comes on. Then I start the engine. If I do that sequence too quickly....no picture on the screen. FR said this is a problem they have seen before and it's a Clarion software problem that newer unit have corrected.
07-31-2013, 04:06 PM
If you want to hold off powering up the screen while your are starting you engine you can install a one shot delay relay inline with the screen. This will hold the screen off until the timer delay has counted down. You can find them at Grainger or other supply houses.
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
08-06-2013, 01:13 PM
Armye7
Did you get your camera fixed?
Got mine back from the dealer (warranty work) they had to replace the right camera.....fixed everything
'Pa Pa's Palace'
08-07-2013, 07:06 AM
They are coming this morning to do all repairs. I will keep you posted. We are at the rally and they have been pretty busy trying to take care of everyone's unit.
08-08-2013, 01:11 PM
Good deal, hope they got you fixed up
'Pa Pa's Palace'
08-08-2013, 04:24 PM
Ours is BACK in the shop, this will be the 3rd time they have replaced the monitor, getting kinda cranky! It will work fine for about 1/2 hr, then it goes out, can't use the DVD player at all. Our unit is a new 2014 georgetown.
Lori
08-09-2013, 06:41 AM
On mine they replaced the right side camera and took care of the whole system....of course the right side was the first indicator it was not working properly. Hope they get you fixed up this time.
'Pa Pa's Palace'
