Old 07-21-2014, 08:16 PM   #11
69BBC's Avatar
Cool. The one in my rig is 3 wires so I figure it should be a quick upgrade. Thanks for the help
69BBC is offline   Reply With Quote
Old 08-04-2014, 03:25 PM   #12
69BBC's Avatar
hey cyclepuck need more info !!!!!!
Wired the power no issue, however when I spliced into the camera I get a no signal on the monitor. The monitor I bought has 2 rca plugs for the camera. I cut the old VOYAGER monitor plug from the camera off and exposed (3) wires, grounded the black. Spliced red and blue onto separate new rca plugs and connected to camera side . no signal. help !!!
Old 08-04-2014, 05:05 PM   #13
Missing Link
cyclepuck's Avatar
The monitor should have a camera one and camera two setting.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 08-04-2014, 06:58 PM   #14
69BBC's Avatar
yep tried both. no signal. maybe I need to splice both wires into the single rca plug ?
Old 08-04-2014, 09:37 PM   #15
Missing Link
cyclepuck's Avatar
I'll look at mine tomorrow. If I remember right it was the yellow video cable directly to camera, a power and ground.
2014 Puma 30-DBSS
Old 08-05-2014, 01:11 PM   #16
69BBC's Avatar
Video in seems to be my problem. Old voyager monitor was a square 4 pin plug from the camera. Cut it off to expose 3 wires: red (power) black (ground) white (signal).
Made an RCA plug and soldered the white on to the RCA plug lead. Grounded this also. Still getting " NO SIGNAL" showing on the blue screen, both AV1 and AV2. Wiring guru's jump in here !!! Larry
Old 08-05-2014, 07:37 PM   #17
Missing Link
cyclepuck's Avatar
Found this. Hopefully it will help http://www.irv2.com/forums/f54/voyag...st-119609.html
2014 Puma 30-DBSS
Old 08-05-2014, 07:41 PM   #18
Missing Link
cyclepuck's Avatar
Or maybe these guys. They offer all kinds of adaptors for the voyager. http://www.jensenrvdirect.com/produc...ories.html?p=2
2014 Puma 30-DBSS
Old 08-05-2014, 08:11 PM   #19
69BBC's Avatar
thanks I will see what they can supply. Problem is that I have already cut the old voyager plug off.
Old 08-06-2014, 11:19 AM   #20
69BBC's Avatar
Called the tech line at Jensen rv / ASA and they were outstanding. The tech guy walked me thru what wires were inside my back camera cable. Seems I had snipped the 4th wire (clear) that is the video signal. White wire is audio. Success I now have an operating monitor. Can start installing it into the dash. Thanks for the help .
back up camera
