Old 07-21-2014, 11:39 AM   #1
69BBC's Avatar
back up camera system
Our 2006 georgetown had a dash mounted monitor. As we rattled over the highway potholes the unit fell back under the dash cracking the dash panel . Got home and cant believe the weight and how it was mounted. Now looking to replace the monitor. Went online to amazon and they sell 7 in. monitors that would seem to work instead of the old unit . Hoping to use the existing camera and simply adapt the wiring in the dash to adapt to the new unit. Is this workable ? thanks Larry
69BBC is offline   Reply With Quote
Old 07-21-2014, 03:16 PM   #2
69BBC's Avatar
Was surfing the net for a bit. These seem feasible , anybody have any good or bad experience with these type of units. Wireless ccd mounted back up camera with 7 in. monitor. Amazon sells then around $250. One I looked at was from TADIBROS.
Old 07-21-2014, 04:57 PM   #3
Missing Link
cyclepuck's Avatar
You should be able to wire up your own monitor without issue. I made my own kit for my truck that works great for about $45 buying the pieces separately. I tried a wireless and it wasn't very good. The more metal the signal has to go through the worse the reception will be and other wireless electronics will mess with it such as Bluetooth. What connection was on the monitor that broke?
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 07-21-2014, 05:42 PM   #4
69BBC's Avatar
Connections are both ok, the camera and the monitor both still work. The mounting brackets to hold the monitor split the dash and I can not glue them back in place. I still have power in the wires and the camera wire is good. Probably buy a new monitor and try to splice the wires, looks pretty straightforward.
Old 07-21-2014, 05:56 PM   #5
kenandterry's Avatar
You don't mention what brand of monitor you have in your rig. Ours was a Voyager model VOM 784CT. They are no longer made.......old technology....CRT picture tube design versus today's models flat screen. We upgraded with the newer flat screen 7" monitor and adapter cables.
Are you going with an entirely new set up or trying to re-use the existing monitor?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 07-21-2014, 06:06 PM   #6
Missing Link
cyclepuck's Avatar
You can get a new 7" monitor for about $30 on amazon with two options in mounting brackets. Just connect the video in and splice into the power that was powering the previous monitor and good to go.
2014 Puma 30-DBSS
Old 07-21-2014, 07:17 PM   #7
69BBC's Avatar
My old monitor is a voyager. The camera is working and so is the monitor but it is to heavy to remount into the dash panel so I really need to upgrade. Like the camera when towing the car and want to get something to replace it asap.
Old 07-21-2014, 07:20 PM   #8
Missing Link
cyclepuck's Avatar
Brand new 7 inch TFT LCD Digital Car Rear View Monitor With Remote and Stand by sunvalleytek http://www.amazon.com/dp/B004Y3FE6O/..._Q3AZtb0JKQXQA
2014 Puma 30-DBSS
Old 07-21-2014, 07:59 PM   #9
69BBC's Avatar
easy to splice the wires on the sunvalley set up ?
Old 07-21-2014, 08:08 PM   #10
Missing Link
cyclepuck's Avatar
Don't know how the sunvalley is set up but most are fairly similar. The one I've done are three wires. Power, ground and signal.
2014 Puma 30-DBSS
back up camera
