Old 06-01-2010, 09:29 AM   #11
Our 2010 Georgetown 341DS has a PrecisionView camera that only gives 1 view and that's down toward the hitch. The book mentions a remote control and left/right views but I think ours is just a single view setup.
Gator_38 is offline   Reply With Quote
Old 06-01-2010, 10:48 AM   #12
powerboatr's Avatar
once you get it all set up
its recommended to adjust the camera down so you can just see your hitch or other protrudence from your rig to use a a reference when backing up.
i tried it, and then went back to where i could see the tongue and both lanes next to me at the rear. i figure if the object is that close i should be stopping.
like most i have a great wife that directs me backing up
great feature is i can hear her, or choose not to to
when they switched out mine from b/w to hd color it was like night and day
its almost to real
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 01-07-2011, 11:53 PM   #13
jsutherl's Avatar
Did anyone remove one of those Voyager black and white cameras? I'm looking for one but I'm not willing to pay the $170 they want for a new one.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 01-08-2011, 07:40 AM   #14
Wanna Be Camper
SaskCampers's Avatar
Ebay.. Item 330492781092
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 01-08-2011, 01:18 PM   #15
jsutherl's Avatar
$140 after shipping. Getting better!
Old 01-09-2011, 01:29 PM   #16
Anacortesians
On our 02 Georgetown, I had the same view-angle problem. I took the cover off to adjust it, then when I went to put the cover back on, it hit the camera and reset it down again.
On further investigation, it turned out tht the inside of the housing hadn't been machined out. A couple of minutes with the Dremel solved the problem There's enough clearance now to adjust the angle to watch airplanes, if I need to!
Frank and Eileen
No longer RVers or FR owners
