Originally Posted by Rongrice
Has anyone else had trouble with their backup camera lense fogging up or getting coated with water when driving in the rain? And if so, has anyone had any luck with a fix to stop this?
Is it fogging up on the inside of the lense or just on the out side? Most camera's have a protective clear over the camera lense, some of these lenses can be removed for cleaning. If you have one of these protective lenses on your camera two things may be happing 1. The lense may become loose and has back of to allow mosture to get in between the protective lense and the camera lense 2. If the protective lense is not removable then it may have a bad seal around it. You can check with the manufacture.
If it is fogging up on the out side, this sometimes happens, if the camera lense is warmer then the rain you can get condensate build-up on the out part of the lense, once they both become the same temp the fog should go away.
This happens sometimes with the side mirrows on my truck when i park it in the garage and then pull it out when it is cool and damp.
