Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Motorhomes > General Motorhome Discussion > Georgetown
Old 06-10-2011, 05:09 PM   #1
Backup monitor shows everything backwards
Fellow Campers.
The monitor on my backup camera shows everything backwards. What is on the passenger side rear of my rv shows on the driver side of the monitor and Vise Versa. Quite confusing and almost impossible to use.
The dealership I bought it from, in all their infinite wisdom, said that was normal. I called BS, but as this is the first backup camera I owned, let it go. With investigation, and viewing other backup cameras, my initial thought of BS was right.
Have any of you seen this phenomenon, and if so, how would you suggest fixing it. My coach is a 2005, 375 XL. Thanks for any and all your help.
Ron
Rongrice is offline   Reply With Quote
Old 06-11-2011, 09:15 AM   #2
Anacortesians
"Normal" TV shows the left side of the camera view on the left side of the monitor, but you're right, it's very confusing when the monitor image doesn't look like it would in a mirror.
Most systems have a switch (in the camera or in the monitor) to switch to "MIrror Image". In some very modern digital systems, there's a menu item to do the switch. I'd suggest looking on line for your system manufacturer's web-site if you don't have a user guide for it in the documentation you got with the MH.
Frank and Eileen
1 Rescued Male Labrador - Bailey, 9 in July
02 Georgetown 325, F53 V10
Old 06-11-2011, 11:06 AM   #3
Thanks, didn't know that. I will check online, and then see if there is a menu on screen.
Ron
Old 06-12-2011, 10:51 PM   #4
Just figured it out
I just removed the dash that held my back up monitor, lo and behold, there is a switch on the back that reads nor/mir. Simple as that. If anyone else has this problem, go to the back of the monitor. Took 2 minutes, rather than a few hours searching the net with no success.
Ron
Old 06-13-2011, 06:43 AM   #5
Don't forget to thank the dealership for all their "help"
peskin is offline   Reply With Quote
Old 06-25-2011, 01:00 PM   #6
jsutherl's Avatar
Here is the manual for the Voyager VOM-78 monitor system that is in my 2008 Georgetown. I think that it's probably the same unit in yours.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 07-08-2011, 08:12 AM   #7
Out up with that reverse image for two years on my 99 coachman Very unnerving when you see a car passing you on the RIGHT side New one is correct at least
CanadianRVER is offline   Reply With Quote
Old 07-08-2011, 09:02 AM   #8
Anybody need a Voyageur monitor...I have a brand new one never used...????
polkatronron is offline   Reply With Quote
Close [X]
