Old 07-22-2014, 02:27 AM   #1
Backup/Reverse Camera Not Work
Hi All,
I have a new 2015 351DS and went on a trip this weekend. All of the sudden, I noticed my reverse/backup camera doesn't work anymore. It was fine when I started the trip.
The screen says "No Signal". The left and right cameras still work when you use the turn signals.
Could a wire be loose or is the camera itself dead? Does anyone have any clue what I should check for?
Thanks.
Sith
sithc is offline   Reply With Quote
Old 07-22-2014, 05:47 AM   #2
I am not trying to be a smartness but the cam is still on the mh?
rwehba is offline   Reply With Quote
Old 07-22-2014, 06:04 AM   #3
I've had the same issue before but usually I can toggle the video input and the screen returns. If you have a video button (mine is labeled V1/V2), you might try pushing it a few times and waiting on each input to see if it will come in. This has always worked for me.
familycamper5 is offline   Reply With Quote
Old 07-22-2014, 09:22 AM   #4
GABoy's Avatar
If your not getting signal then either the power or RCA cable is disconnected somewhere.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 07-22-2014, 12:01 PM   #5
rwehba, yes the camera is still back there. :-)
I've tried the video input (v1/v2) buttons to cycle through the left, right, rear cameras.
Left & right work, but when I get to the rear camera (aux3) the screen is blue with the words "No Signal" on it.
Where can I find the RCa or power to the camera?
Old 07-22-2014, 12:19 PM   #6
GABoy's Avatar
Should be in a bundle behind monitor. Might be as simple as a RCA plug wasn't plugged in properly from factory and came loose. Or the fuse could be blown in line power cable. If not that will need to have dealer check out.
Chevy Colorado Crew
Old 07-25-2014, 09:53 AM   #7
Lorigirl10's Avatar
We had a lot of problems with ours, if it wasn't one thing.. After the FIX... It was another! After 3 changes it's finally working correctly .
Lorigirl10 is offline   Reply With Quote
Old 07-25-2014, 10:30 AM   #8
Sbryant's Avatar
Behind the monitor, when you unscrew and pull out the dark console cover that holds the monitor and switches, there is a small black box with the 3 camera cables plugged into it. It is marked left, rear, and right. Your rear may have become unplugged - mine did, and after I plugged it back up, I siliconed all 3 in place.
Sbryant is offline   Reply With Quote
Old 07-25-2014, 12:57 PM   #9
Thanks Sbryant, I'll try to take a look when I get the chance.
Old 07-26-2014, 06:30 AM   #10
2013 GEORGETOWN 351 DS
RELHUB's Avatar
Try the easy fix first, turn it off and then back on. This seems to always work for my unit
GRV
We love to Roam
2013 Georgetown 351 DSF
2013 Nissan Sentra
RELHUB is offline   Reply With Quote
