Old 06-09-2016, 09:24 AM   #1
Bayouownbeer's Avatar
Ball hitch for 2" receiver
Just picked up a 2017 364TS and want to pull toe dolly with 4K LB car and 12" atv trailer no at same time. What kind of hitch I need? I use a 5 1/4" drop on my 3/4 4x4 truck but I don't think that is enough drop. Looks like I would need 10" the receiver is high on the back. Can I use this?
https://www.etrailer.com/search/Trailer+Drop+Hitch
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 06-09-2016, 10:16 AM   #2
jergeod's Avatar
I use an adjustable hitch which if you look at them they are much more substantial than the one you are looking at to pull 2 1/2 ton and stopping it. Your receiver is most likely rated at 5000 lbs so with the dolly you will be at almost max weight.
MaxxTow Adjustable-Height Ball Mount - 2" Hitch - 10" Drop, 8" Rise - 5,000 lbs Etrailer $59.95
Then I replaced the pins with bolts once I found the proper height.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 06-09-2016, 10:30 AM   #3
Great thanks I found it
Old 06-10-2016, 09:04 AM   #4
Ten inches seems like a huge drop. I don't think my drop is that substantial and my 2011 330 sits on the 22K chassis. I tow a Master Tow Dolly. I bought my drop bar at K-Mart and most auto parts stores and local trailer supply stores will have a selection that will fit your needs. That way you can exchange it if the one you go with needs to drop more or less.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 06-10-2016, 09:16 AM   #5
The back of the 364TS sits high. It's about 4" higher than my reciever on my 4x4 f 250 that I use 5 1/4 drop for. So with the adjustable hitch I can put it where I want for the toe dolly and my atv trailer is a dove tail so back it already low.
Old 06-10-2016, 12:13 PM   #6
Head Rambler
Here are some adjustable ones. That way you can adjust it to suit each towed vehicle or trailer.
adjustable ball mount
Gotta go campin!
Old 06-10-2016, 06:08 PM   #7
I believe there are different weight ratings on these hitches. The 5,000 lb is a hollow 2" square tube and the 7,500 lb is solid 2" square.
PenJoe is offline   Reply With Quote
Old 06-10-2016, 07:09 PM   #8
Yeah I'm not towing over 5. My car weights 4 and toe dolly
Old 06-14-2016, 08:39 AM   #9
Boy that link to e-trailer has some beauties for an option. Have the wallet ready, ouch!
sherman12
Old 06-14-2016, 08:44 AM   #10
Yeah buddy I went with the cheap one lol
hitch
