Old 02-02-2014, 01:14 PM   #1
Battery Charger
I am adding 2 additional 6 volt Trojans for a total of 4 batteries for the coach since I am tired of buying batteries every year. Dry camping for a few weeks puts a strain on the 12 volts and the number of cycles shorten's the life of the battery. Now the question is: does anyone know what size, as in how many amps, is the factory installed battery charger, ie "converter" . Also thinking about additional solar panels to the lonely one on the roof. The recommended charger rating is: total amps of solar array divided by 5, so a 460 amp-hour array (4 panels) would need a 90 amp charger.
MattM is offline   Reply With Quote
Old 02-02-2014, 04:29 PM   #2
Iggy's Avatar
Answer #1 : Mine says 70 AMP on the label. (See Picture)
Answer #2: I thought solar panels were rated in watts at 12v dc?
So if you want 90 amps you will need 1080 total watts of power at 12 Volts DC to produce 90 amps at 12 volts DC.
Iggy is online now   Reply With Quote
Old 02-02-2014, 06:35 PM   #3
Thnx Iggy. The formula came out of FMCA magazine
Old 02-03-2014, 08:00 PM   #4
Go to http://handybobsolar.wordpress.com
Priceless!!!
DennyH is offline   Reply With Quote
Old 02-06-2014, 10:22 PM   #5
Cornelius's Avatar
^ Agree.
Handy Bob is an excellent resource for learning about RV solar.
Cornelius is offline   Reply With Quote
Old 03-02-2014, 09:51 AM   #6
Well, I had a fabricating shop build a new battery tray and installed in under the steps for a total of $250. Tight fit but workable. Then I used welder's cable, 2 gauge, since it is more flexible, and had my rv repair tech install that. Cable and terminals $80 plus 2 hrs labor at $85 per hr for $170 total. Bought 2 new Trojans T-105 for $260 and 2 more Trojans to replace the 12 volt Deka's. They pro-rated the cost at $50. So total cost to upgrade to 4 six-volt Trojans: $550
So, next step installing an inverter. But should I get an inverter/converter and replace the factory converter?
Old 03-02-2014, 09:59 AM   #7
Witch Doctor's Avatar
most chargers on the inverter are 4 stage. If you are only going to get a 3 stage built into the inverter then I say no, If it comes with a true 4 stage then yes. Just my way of thinking.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-02-2014, 09:59 AM   #8
Iggy's Avatar
It would be great if you showed us your MOD with a few pictures if you can.
Thx
Old 03-03-2014, 02:16 PM   #9
camaraderie's Avatar
Matt...suggest that with around 450amps of wet cells...your bulk charge acceptance rate is gonna be around 90 amps so if you get a combo with inverter...make sure the charging section is at least that big or a bit more to insure the fastest recharge when boondocking. Some chargers offer the 4th stage (periodic equalization) as a part of the charging process. Others make EQ a manual choice on your part. Others don't offer it at all...and should be avoided.
As to solar ... they need a controller..not a charger which is a completely separate issue. The batteries are the limiting factor for solar systems as well...since any system which put out more than 90amps at full output would be useless to your batts just like a larger charger would be. Unlikely on an RV!
You're likely looking at around 20-25 amps at full sunlight out of 400watts of panels so no worries about overcharging your new batts with a good Mppt controller. That would give you 100-120 amp hours back in to them on a typical day.
camaraderie is offline   Reply With Quote
Old 03-04-2014, 09:34 PM   #10
Cornelius's Avatar
One problem I encountered when I needed to replace my defective converter/charger is that Forest River installed it in the last rear compartment with the 50 amp cord. That's about 20 feet from the battery location under the steps. The factory converter/charger was a 65 amp, 13.6 volt single stage Chinese model. I replaced it with an 80 amp Progressive Dynamics 4 stage model that is made in USA. Unfortunately, it is still in the rear compartment 20 feet from the batteries. It is best to have the charger as close as possible (but never in the same compartment) to the batteries to minimize line loss voltage.
When I added solar panels a few weeks ago, I installed the solar charge controller in the cargo compartment immediately adjacent to batteries under the steps. The cables are only about 2 or 3 feet long from the solar controller to the batteries.
battery
