Originally Posted by Walter Pigeon
Shore power is disconnected... disconnected the house batteries and still have power to the propane cutoff and the carbon monoxide detector
That's because they (both the same control) are connected directly to the batteries. There are probably several, inline fused, items connected directly to the batteries that are not disconnected with the disconnect switch. The awning/steps/LP detector/slides, etc.. The propane cutoff/detector is a 5amp inline fuse and it can be relocated from the batteries to the top left stud on the side of the BCC and it will be disconnected with the battery disconnect switch.
Additional; the BCC top left stud is the upper stud on the outside on the right looking at the front removable panel of the BCC. Install it where this view indicates. Stud #1.
