Old 09-20-2015, 08:39 PM   #1
siskom's Avatar
Battery disconnect
When do most of you use your battery disconnect switch ?
siskom is offline   Reply With Quote
Old 09-20-2015, 08:41 PM   #2
Scubanut's Avatar
Whenever it's parked not used for two days.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 09-20-2015, 08:59 PM   #3
tilap's Avatar
On off position when you store it or when you will not be using the RV for a few weeks. Beside that live it on
tilap is offline   Reply With Quote
Old 09-20-2015, 09:09 PM   #4
ferguson65's Avatar
I use mine anytime the camper is sitting not plugged in. We generally plug it in once we return home and leave it plugged in until we have cleaned it. Then the slide gets pulled in, power cord put away and disconnect turned off until we are ready to go back out next. If it's a short turnaround I just leave it plugged in and don't bother with the switch.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 09-21-2015, 07:27 AM   #5
chrisbailey13's Avatar
Anytime it is in storage for more than a day or two, it is switched off.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 09-22-2015, 01:44 PM   #6
Happily Retired Member
I leave my switch on all the time. When in storage in my pole barn the unit is plugged in and this keeps the batteries fully charged. Since they are maintenance free batteries, they are fine. I have always done this, even with three prior 5th wheels and have never had a battery issue.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 09-26-2015, 11:30 AM   #7
how to do you turn it or off?
ztowngal is offline   Reply With Quote
Old 09-26-2015, 11:49 AM   #8
Ford Idaho's Avatar
Mine looks like this, just twist it.
Others look like this, you twist the key.
Old 09-26-2015, 12:36 PM   #9
waiter21's Avatar
When its parked (stored) for more than a few days and its not plugged in.
I have a 4 stage converter so it doesn't boil the battery when I do plug in.
I also installed disconnects on the coach and chassis batteries. (Mine doesn't come equipped with disconnect solenoids) Same with the TOAD that sits in the barn when not in use.
You can pick up these disconnects for 5-6 bucks each. Mount them on the Negative Terminal.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
battery, battery disconnect
