Forest River Forums
Sunline User Photos
Old 12-20-2011, 06:10 PM   #1
Send a message via Skype™ to Falcon35
Battery drain Georgetown 378
How much fantom draw is there when the battery switch is off. I thought that there should be no draw on the coach batteries when the switch is off. When I went to check the coach in storage after about four weeks I had start the engine before the steps would extend. I asked the dealer regarding this and they told me I should disconnect the batteries. I thought that is what the switch was for.
2012 Georgetown 378 2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Falcon35 is offline   Reply With Quote
Old 12-20-2011, 06:18 PM   #2
RV Newbie
buzzards27's Avatar
There are several draws on the battery even when the switch is off (storage). A CO detector among others, I believe.
Either disconnect battery or use a battery minder/ tender.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 12-20-2011, 07:57 PM   #3
The other item that draws power is the leveller computer. I had same problem and installed a disconnect switch right on the batts as well.
polkatronron is offline   Reply With Quote
Old 12-20-2011, 08:11 PM   #4
Tim & Lisa Trempert
My dealer put a blade switch right on the battery post. $25 for the switch and $25 for the 15 minutes of labor as I had it in the shop for other warranty work. It's important to keep the batteries charged in the winter or the water in the battery will freeze and you'll have nothing. Just don't forget to reconnect the blade switch if you start up the coach every few weeks to charge the batteries or they won't charge.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 12-20-2011, 08:43 PM   #5
Thank's:
polkatronron: I do not have a power hookup at the storage lot. If i did the battery minder/ tender would be the way to go.
Trempert: We will be leaving for south TX on January 3 so freezing should not be a problem. I don't like to pull the cover off the step to disconnect the battery every time we store it for a few weeks.
Old 12-21-2011, 04:55 AM   #6
Mountainmanbob's Avatar
smaller solar units - should keep your battery topped off
they have some smaller solar units
that should keep your battery topped off for you
but
you may still have to
pull the cover off the step to connect the solar wires ??
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 12-23-2011, 08:12 PM   #7
JimF's Avatar
In our 387 I have checked the draw on my batteries when the main power switch is turned off and there is zero. The selonid to the switch is from the chassis battery I assume (haven't check that) not the house batteries. When the switch is off nothing happens but the steps will come down on the chassis battery
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is offline   Reply With Quote
Old 12-23-2011, 10:05 PM   #8
Hi ! Falcon35
The attached FR 12VDC drawings may help you to determine
any draw on the batteries during storage.
File Type: pdf Georgetown Battery Connect Center 113174 1 OF 1.pdf (310.0 KB, 40 views)
mbtelguy is offline   Reply With Quote
Old 12-24-2011, 12:13 PM   #9
Thank's mbtelguy,
I just know enough about electricity to be dangerous so will just have to pull the negative wire from the coach batteries until I sort this all out. I'm sure that it also over the head of the service department at me dealer.
Old 12-24-2011, 01:09 PM   #10
if I was only going to pull one terminal
and I do often
I pull off the positive
gess it don't matter ?????
just the way I was taught in auto shop
and what we did
as operators on the job
Mountainman
Close [X]
