Old 09-05-2016, 07:30 PM   #1
Battery help
Ok, I know that this subject has been covered in various ways but I'm going to approach it again. I have started to do my homework on installing permanent solar panels on the roof that I could trickle charge the two coach battery's while we are not using the unit. I have a 2011 337DS so I would appreciate hearing from any of you that have successfully done this, and of course photos will get "extra credit"!
Thanks in advance...
Marvlab is offline   Reply With Quote
Old 09-05-2016, 07:33 PM   #2
Bluepill's Avatar
My factory install is a 10 watt panel used to maintain 3 group 31 batteries. As a maintainer only, it works fine. Batteries must be fully charged before storage.
How will you maintain your chassis batteries?
2008 Itasca Meridian 37H
Old 09-05-2016, 07:43 PM   #3
Thanks Bluepill, you say yours is factory? I'm somewhat new to this so was not aware this was a factory option, but it does make sense.
I'm looking for information on reliable panels and electrical components to use in an aftermarket install.
Old 09-05-2016, 08:21 PM   #4
Bluepill's Avatar
Factory installed on my motorhome. Circuit is just a panel with a reverse blocking diode. No controller needed because of the small output of the panel (about 0.7 amps maximum).
If you are just using for off-seasonal storage, you don't really need a permanent installation. Just a line from the panel to the batteries, connected with small alligator clips. If you want it for short-term storage between uses, it would probably be worth a roof top installation.
Something like this:
Battery Tender 021-1163 5W Solar Maintainer
Copy & Paste description into google.
You may need more than 5 watts if you total Amp Hour battery capacity is over 150.
Old 09-05-2016, 09:00 PM   #5
Thanks Bluepill, sounds like what I'm interested in!
battery
