Old 02-16-2015, 10:52 AM   #1
Senior Member - Retired
Battery Watering
It is a bit difficult and certainly time consuming to remove the vent cover caps from several of my batteries in order to check the water level in the cells. There are several products on the market that claim to provide an “easy” way to regularly check/adjust water levels.
Following are links to two systems on Camping World and a link to a manufacturer website:
http://www.campingworld.com/shopping/item/on-board-battery-watering-systems-48-volt-kit-for-four-12-volt-batteries/77298
http://www.campingworld.com/shopping/item/qwik-fill-dual-12-volt-battery-watering-system/27037
https://www.flow-rite.com/battery-watering/pro-fill/part-number-generator
Has anyone installed any type of system they are happy with?
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 02-16-2015, 12:23 PM   #2
BillMFl's Avatar
Happiness is sealed deep cycle. No watering. Also my LP detector no longer goes off all the time.
BillMFl is offline   Reply With Quote
Old 02-16-2015, 01:31 PM   #3
WDK
WDK's Avatar
.....yeah!!!!
WDK is offline   Reply With Quote
Old 02-16-2015, 03:32 PM   #4
bend302's Avatar
Yes: I have the one similar to Camping World. Bought it at the Goshen rally a couple of years ago.
Just connect the tube, put other end in distilled water bottle and squeeze bulb. Do that about once a month when set up here in FL over the winter and whenever I begin a trip in the summer.
I like the system and hope it will save my batts from getting too dry.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 02-16-2015, 08:16 PM   #5
Iggy's Avatar
I bought this on my first set of OEM Georgetown batteries but removed when I got my new set of batteries.
Its ok but you can possible over fill if you don't follow the directions when filling.
I really don't think this is worth $60 and would be glad to sell you mine for $20 plus $5 shipping if you like.
Old 02-16-2015, 08:29 PM   #6
BillMFl's Avatar
haha you da bomb Iggy These gadgets work great on a bench. Not so easy under the steps, etc.
Old 02-16-2015, 08:48 PM   #7
Cornelius's Avatar
A turkey baster from the $1 store works well for adding distilled water to the batteries. Keep it simple and cheap!
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 02-16-2015, 09:08 PM   #8
ramair's Avatar
I'll Get it from you Iggy. I will hook up with you when we go to Goshen.
If not let me know and we can make arrangements.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 02-16-2015, 10:41 PM   #9
Iggy's Avatar
Sure you don't want to use the turkey baster?
All I need to do is find it and remember to put it in the rig before I head to Goshen.
Old 02-18-2015, 07:25 PM   #10
Send a message via Skype™ to Falcon35
I would not like to be without it in our Georgetown because of how the batteries are mounted under the steps.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
battery, water
