Re-programmed slide switch
Well, I learned that the green button and red button are programmed to blink different times for different fault codes. I didn't realize that fact .The red button blinked 4 times which I found out was a motor fault . I followed the steps to reset or program the slide switch and whoop woop it worked. I believe the problem started when I disconnected the battery to replace it. If you don't have enough battery power things go wrong. A few weeks ago my awning would not retract because one of my batteries was bad so I didn't have enough juice to operate. When I started the engine ( dry camping) after a few minutes I had enough juice to retract the awning.
