If they were working and not stopped you may want to check the level of your batteries. A fuse can look good but be bad the only sure way to tell is use a multimeter and check it. I would not change the position of any valves until you verify the other things are good. let the forum know what you find and correct.
Retired Navy
2016 Flagstaff 26 FKWS
