Old 03-18-2016, 05:51 PM   #1
Bedroom Slide Leak
Our 2015 Georgetown XL 378 has a bedroom slide leak that so far the dealer hasn't been able to repair. There is a channel under the slide on the outside that fills up with water during rain storms and than overflows onto the floor of the bedroom. The seals look fine. Any suggestions would be appreciated. Thanks!
garybakr is offline   Reply With Quote
Old 03-18-2016, 05:58 PM   #2
Should there be drain holes in the Chanel? Kind of like the ones on the bottom of the window frames.
beachcamper is offline   Reply With Quote
Old 03-18-2016, 06:04 PM   #3
SeaDog's Avatar
As has been said check the channel it may be filled with caulk clean out any drain holes you can find.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 03-19-2016, 02:27 PM   #4
Stopped raining so I could check the channel. No weep holes I can see. I'm leaning that one of the seals is allowing water inside where the seal snaps onto the RV body. Looks like there is some bad sealant holding the seal on. Will try that next when things dry out. Thanks for the thoughts.
bed, bedroom slide, leak, roo, slide
