Old 05-13-2016, 05:29 PM   #11
Sc00ter's Avatar
X2 for the Edge. Went with the CTS for the larger screen. Just did the revisions last week. Works on all my cars though some don't have all the same gauges (jeep Cherokee and Ford Explorer don't have trans temp like the truck does).
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is online now   Reply With Quote
Old 05-13-2016, 05:49 PM   #12
BendOrLarry's Avatar
Thanks for chiming in. I was attempting to explain that the scanners only scan and read what the rig sends to the OBDII port. If the rig does not have a tranny temp sensor in the tranny, then no scanner can provide that info.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 05-13-2016, 05:56 PM   #13
I found it. It says you need the Ultra Gauge MX version of the product to read the tranny temp. I assume that is what you have since it sounds like you have tranny temp on yours.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-13-2016, 06:07 PM   #14
No my rig doesn't have a tranny temp sensor in the tranny. You need to research if your rig does or no scanner will provide that gauge. I believe that there are links to sites that provide that rig specific info on the Ultra Gauge site. From the beginning I have said yes it will show tranny temp IF your rig provides that info to the OBDII port.
Firestone airbags
Old 05-13-2016, 06:08 PM   #15
Flybob's Avatar
As mentioned above, even though the scanner can support the parameter you are looking for, the vehicle computer may not support it. The scanner/reader simply sends a request to the computer to return the value of the parameter desired. If the computer does not support ( understand) the request, it fails. A fail could be because the vehicle does not have a sensor for that parameter, or that the parameter is only used by the vehicle computer and not available for export.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-13-2016, 06:18 PM   #16
John McClain's Avatar
Originally Posted by Flybob View Post
I use the Edge Insight. Provides everything you could ever ask for in an easy to see color format. Shows he soot level in my Duramax and when it is regen mode ( also can force regen) .
x2
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 05-13-2016, 06:40 PM   #17
shughey00's Avatar
Ditto..love the EDGE CTS
2004 Cedar Creek 34CTKS heavily customized
2006 Ford F350 FX4 Lariat Dually w/tow boss
1999 Lance 1110...cause it's easier for short trips.
shughey00 is offline   Reply With Quote
Old 05-13-2016, 09:00 PM   #18
Best Engine scanner
I already know my truck has a sensor because I have a worthless Ford dumb gauge which starts moving at 234 degrees. I bought my Scangauge 6 1/2 years ago specifically for the tranny temp and the rest is all a bonus. I am just curious at what else is out there now.
I don't know what vehicle you are referring to that doesn't have a sensor. That would be uncommon for a truck.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Old 05-14-2016, 12:32 AM   #19
I go RV'ing not Camping
jgourlie's Avatar
I use the torque app and an obd2 Bluetooth dongle. I think I am into it for $20. I have used it on my last 4 vehicles and it works like a charm
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-16-2016, 01:49 PM   #20
I also use Torque for Android. $4.95 for the Pro version, completely customizable. You can set up gauges for any data available on your OBD bus and you can set up alarms to alert you (say your coolant or transmission temp goes above a certain value) so you don't even really have to keep your eye on it all the time. Here's the Play Store listing for the free version:
https://play.google.com/store/apps/d...owl.torquefree
and the Pro version:
https://play.google.com/store/apps/d...g.prowl.torque
And this is the OBD2 bluetooth adapter I have (very similar anyway). Only $10!
Super Mini OBD2 OBDII ELM327 V1 5 Android Bluetooth Adapter Auto Scanner Torque | eBay
carmex is offline   Reply With Quote
