Old 05-13-2016, 10:36 AM   #1
Best Engine scanner
I am looking to buy an engine scanner to place on the dash so I can monitor temp and any other needed info.
What are the better models out there?
Even if there are ones that are wireless to connect to iPads or tablets I would consider.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 05-13-2016, 11:06 AM   #2
Retired May 2015
Just bought and installed a Banks IQ2 with auto mind programmer. Scan gauge ll is a good alternative from Bulletproof Diesel, order online. Just my .02 cents worth.
Dennis & Carol
2005 Bulletproofed F-250 6.0 Crew Cab/Long Box
2007 Forest River 38 ft Sierra
Retired 4/30/15
Traveling with new pup "Sammie". Boston Bull Terrier/chihuahua (Bo-huahua). Pronounced Bow wow wow.
dwcjb is offline   Reply With Quote
Old 05-13-2016, 11:29 AM   #3
BendOrLarry's Avatar
I have the Ultragauge and really like it. Larger display than the Scan gauge and a lot less expensive as well.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 05-13-2016, 01:26 PM   #4
Does the Ultra Gauge have transmission tempurature?
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-13-2016, 01:51 PM   #5
Flybob's Avatar
I use the Edge Insight. Provides everything you could ever ask for in an easy to see color format. Shows he soot level in my Duramax and when it is regen mode ( also can force regen) .
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-13-2016, 03:59 PM   #6
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Just like all the scanners, it reads what the manufacturer provides to the OBDII port.
Firestone airbags
Old 05-13-2016, 04:19 PM   #7
For less than 50 dollars a OBD dongle and the smartphone app Torque. The dongle sends a WiFi signal to your smart phone that via Torque displays everything the chassis might allows you to see. As a benefit you can also read and clear codes
donniedu is offline   Reply With Quote
Old 05-13-2016, 04:22 PM   #8
I have one of these and it does work, but in practice a pain in the butt. You have to set it up each time you want to use it. A dedicated gauge, comes on when the engine starts, does not require any set up (after initial set up) and no battery to charge.
Firestone airbags
Old 05-13-2016, 05:06 PM   #9
It that a yes or no? I didn't see it listed in the gauges on their website. Maybe I missed it.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Old 05-13-2016, 05:08 PM   #10
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
It's a yes, if your rig produces it, it's a no if it doesn't. All the scanners are like that.
Firestone airbags
