01-16-2017, 07:50 PM
Best fuel additive when stored
What do you think is the best additive to put in your RV gas tank when its being stored for the winter? Most years instead of adding anything I try to drive awhile, use up 10 gallons or so and add fresh fuel. This has worked ok for 6 or 7 years that I have owned a class A. But would like to know what other folks here are using and would recommend.
01-16-2017, 07:59 PM
The only gasser I have that sits in my rider lawn mower, I use Sta-Bil in it.
01-16-2017, 08:18 PM
DW's 401(k) Plan
I added Sea Foam to my tank and then ran the engine as well as the generator before storing. Each time I go to where the RV is stored, I take about 5 gallons of fresh fuel with Sea Foam to put in the tank, start the engine and also run the generator for about 15-30 minutes with a load - usually a heater. Tank wasn't full when I took it for storage, so, a few trips will fill it.
From the Sea Foam website - "Sea Foam stabilizes fuel by resisting evaporation, gum and varnish formation". Of course, use as directed.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
01-17-2017, 12:20 AM
Sea Foam
01-17-2017, 12:26 AM
I am a big fan of Star tron fuel treatment.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
01-17-2017, 01:59 AM
sta-bil use it in all my small engines and cars that I have in storage. one pull on most small engines. cars start up and run like the day I parked them after one year of storage. also use the diesel sta-bil in my trucks to keep the fuel stable.
Hope This Helps Tim
01-17-2017, 06:51 AM
I'm using the Onan fuel stabilizer that Onan recommends. I add it to the chassis tank (obviously) and run the generator to also get it into that carb. During the winters, once/month, I run the generator as well as the chassis engine to keep things in shape.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
01-17-2017, 07:16 AM
Salt
I am in this corner for the past 10 years,Star Tron! Youroo!!
01-17-2017, 10:13 AM
Power Service: Diesel Additives. There is a downloadable PDF sheet that provides you with information on what product you need to use. The one that I recommend would be "Bio Klean Diesel Fuel Biocide" for long term storage. If you are using diesel fuel for your Class A.
See attached link: Power Service
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
01-17-2017, 01:35 PM
Salt
X-2 on Star Tron... Seafoam too
01-17-2017, 01:58 PM
Star Tron
I used to use Stabil but now use Star Tron. It was recommended by a trusted friend in Oregon who uses it in boat outboards that are stored over winter months. It supposedly last up to 2 years he says. I don't know but I trust him and so now I use it and have no complaints.
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
01-17-2017, 02:10 PM
I've using stabil for years on boats, rvs, lawn mowers, trimmers.... Everything starts righ up after storage. Once snow blower was seating for two years with Stabil, it started with two pulls. I also make sure the tanks are topped off.
01-17-2017, 02:13 PM
On my chainsaws and small engines I try to use recreation fuel (no ethanol) when it is convenient. Probably too expensive to fill the MH tank with it though as it is 30 to 40 cents more than regular gas. So I add sta-bil marine/storage when topping the tank for storage. The sta-bil marine/storage neutralizes the ethanol and prevents varnish. Been working good for years on my portable generators, showblower, lawnmowers, MH, etc..
I have rebuilt a lot of carbs (not mine) that have been left for extended times with efuels in them.
01-17-2017, 02:50 PM
I have always used marine Stabil or Startron in my boat outboard engines and lawn mowers when storing for several months with no problems.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
01-17-2017, 03:09 PM
Star-Tron for gasoline.
Power Service for diesel.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
01-17-2017, 03:20 PM
Lots of 'magical elixers' out there. I'm all about Stabil as well. The Marine stuff, not the stinking red crap.
Seafoam is Stoddard Solvent and nit much else. Good for a carb cleaning if you have a carb that is.
01-17-2017, 04:44 PM
I use Stabil in the boat. 80 gallons sits from October till April. I run it for a while to make sure it gets pulled through the lines and filters before shutting it down for the winter.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
01-17-2017, 06:13 PM
One thing to always keep in mind (no matter what fuel stabilization product you use) is..
When laying up any motor driven vehicle or boat for the winter or for any length of time, like snowmobiles in the summer, always make sure the fuel tank is full to the top because the air above the fuel in the tank promotes fuel degradation.
01-17-2017, 07:38 PM
Startron stablizes for up to two years and contains enzime to make ethanol into something that wont destroy your rig.I buy mine at wal mart in the marine dept.there are different strengths at different prices so beware,wally world sells the stranger one.
01-17-2017, 08:17 PM
Well JR I believe you and will look for the "stranger" one. And thanks to all that replied.
