Old 04-10-2019, 05:02 PM   #1
Max49's Avatar
Best place to get 12 Volts
My 2018 Georgetown 24W is my 4th motorhome. It's my 1st motorhome that has 0 as in zero 12 volt outlets in the house area. Do you think they never thought about people needing to charge their cell phones? Sometimes you have to wonder what the designers or engineeers were thinking.
So , I assume the 2018 24 W is not the only Forest River without any 12 volt outlets. Where have you guys tapped in to get a 12 volt outlet. Since the dining table and bed are where I need them and both are in the slide out, is the overhead LED lights the best place? I'd really rather not have my charge wires plugged in up overhead at the ceiling, if I tap in elsewhere, Ihave to fanangle the wires so they slide in and out with the SO.
Any suggestions?
Thanks, Max
Max49 is offline   Reply With Quote
Old 04-10-2019, 05:17 PM   #2
Any suggestions?
Thanks, Max
I tapped in to the radio wire and installed 2 of these. While I was in there, I put in a switch so that the radio and these new outlets are switched completely off when desired to reduce parasitic draw.
These are nice because they are high current:
https://shop.pkys.com/Blue-Sea-1045-...xoCrasQAvD_BwE
This is the switch:
https://shop.pkys.com/Blue-Sea-8218-...ey_p_1939.html
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 04-10-2019, 05:21 PM   #3
Do you have any 120 volt outlets? You can buy plugs for the 120 that include USB charging outlets.
DYNAMAX 2016 FORCE HD
houstonstroker is online now   Reply With Quote
Old 04-10-2019, 05:24 PM   #4
cavie's Avatar
Didn't you phone come with a 120 volt charger?? All of mine have always had one. there cheap and available everywhere.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-10-2019, 05:24 PM   #5
Way better to use 12V. That way, no need to be on shore power or use an inverter to power them.
Old 04-10-2019, 05:42 PM   #6
I am surprised that you don't have any 12 volt "cigarette lighter" plugs in the dash. If you don't, you can always buy a couple of them on Amazon for about 5 bucks each. They even have double and triple plug setup with a combination of both lighter plugs and USB outlet. They have under dash and in dash types. That's what I did, I added a couple more outlets to make it convenient for both diver and passenger's phone.
Also, one thing I did was to splice a 120 volt inverter and transfer switch to the right side of the coach's 120 volt outlets so I could have 120 volts while going down the road or at a brief stop at a rest area, without firing up the generator.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 04-10-2019, 06:01 PM   #7
PPST Wannabe
kenandterry's Avatar
Any suggestions?
Thanks, Max
I’m assuming your definition of “outlets in the house area” would be the area of the Georgetown anywhere behind the driver and passenger seats. This will eliminate the cockpit area for referencing any 12 volt outlets.
In my rig then....the only factory 12 volt outlet is the one that is part of the TV Booster plate. This is the button you push for amplifier power for using the rooftop antennae for television viewing.
Any outlets that anyone would want other than this one, is up to the owner to install. Not that difficult to tap into any factory lighting for power.
Like others have mentioned, most people charge their cell phones by using the 110 volt outlets, just like they would at home. These types of outlets are located in a variety’s of locations depending on the floor plan of your rig.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 04-10-2019, 06:03 PM   #8
Prime Member
I don't have your camper but I tapped directly into the 12V at the main breaker panel.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 04-10-2019, 06:42 PM   #9
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Tap into the TV booster switch. Add a USB or cigarette lighter plate. Just be careful how much power you are drawing if you go the cigarette lighter route and try to use large current hog items.
Otherwise, go on the hunt for power and tap into that. The power for the overhead lighting usually leaves the slide out under the slide. Tap into that and run your own feeds. If you do that, beware of the slide rollers or wipers when running your wires.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
A Loving wife
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 04-10-2019, 10:38 PM   #10
cavie's Avatar
I think this will solve your problem very easily.
https://www.amazon.com/s?k=120+volts...ref=nb_sb_noss
12 volt
