Old 12-23-2011, 12:16 PM   #11
The one car thats been flat towable since its itroduction has been the Honda CRV. Just hook it up,follow the little procedure and take it away.Im on my 4th one since 1998. Its probably the most the most dependable car you can own also. Besides the new ones are 95% made in America.
johnnypal is offline   Reply With Quote
Old 12-23-2011, 11:46 PM   #12
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Not true. The top five were toyota camry, honda accord, ford escape, ford focus and the chevy malibu. The CRV was not even in the top ten so was under 75%. I got my information from cars.com. Also the Saturn Vue has been flat towable since its introduction and is continued in the the Chevy Equinox and GMC Terrain which are on the same frame as the Vue. Don't get me wrong the CRV is a great toad but so are the two I listed. Also, might be better to say the CRV is "one" of the most dependable cars you can own without stating where you got your information. It certainly wasn't from experience since you never kept any one of them more than three years.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 12-24-2011, 08:46 AM   #13
Nemo, all the cars you mention Might be flat towable with thier latest year offerings but all of them including your Equinox required special equipment for flat towing in thier earlier years. The early Saturn Vues were equiped with Honda power trains.Take a look in the Consumer reports yearly buying guide for reliability records.
Old 12-24-2011, 09:30 AM   #14
senforex's Avatar
You can verify your car in the Motorhome Towing Guide
http://www.motorhomemagazine.com/Din...-Towing-Guide/
senforex is offline   Reply With Quote
Old 12-24-2011, 11:12 AM   #15
nemo45's Avatar
In its ealier years the Equinox with the 3.4 V6 and the 5 speed tranny had to be towed with a dolly but the Equinox Sport with the 3.6 V6 (same as the Vue) with the 6 speed tranny could be pulled four down and by just removing a fuse. You could not get an Equinox with a 4 cyl. like the CRV until the 2010 model. The early 3.4 V6 Equinox's had head gasket problems but they have been resolved, I don't think they even use that engine anymore, and the 4 cyl. has had no such problems. My 4 cyl. Equinox has the 6 speed transmission and they have been towable four down since its inception in the 2010 model. By the way, you should be pulling a fuse on your CRV to tow it too. A couple of my friends with CRV's didn't know this and one had a dead battery when they finished the day towing because they left the radio on. I am just saying by my experience my Equinox has been a great toad and there are alternatives to a CRV. Some of the Jeeps and the Ford Exscape also come to mind. If you want a larger vehicle the GMC Acadia, Chevy Traverse and Buick Enclave are all towble four down and by just removing, in their case, 2 fuses.
Old 12-24-2011, 11:47 AM   #16
Nemo, The main point I was trying to stress was that you could buy an old CRV or Saturn S series and tow it flat.People who dont want to spend a lot on a toad are still looking for these old cars. These were the only ones in those years.As far as pulling a fuse goes, I never did and never had a dead battery. As far as reliability goes,both the Saturn S and the CRV had the best records in the industry going way back.
Old 12-24-2011, 12:51 PM   #17
Another resource for information is:
Application Charts | Remco Towing
This resource lists not only the vehicles that can be towed without modifications but also the vehicles that can be towed with modifications (and tells you what modifications are required). Also listed are the vehicles that cannot be flat towed at all (even with modifications). And, of course they sell the stuff you need to make the modifications
MikeA is offline   Reply With Quote
Old 12-24-2011, 01:24 PM   #18
nemo45's Avatar
And you could buy most any car with a manual transmission and tow it four down, if you wanted a really inexpensive toad. My buddy that had his battery go dead after towing never had it go dead again either, but after that he never left the radio on. Anyway its in your owner's manual, but it states that you need to do it if you're going to tow long distances. With the Equinox there are other things on that fuse that would run when the ignition is in the on position like the vehicle info screen and key in the ignition buzzer. Anyway, to the OP. I have towed both with a dolly and four down and to me, four down wins hands down.
Old 12-24-2011, 01:41 PM   #19
Nemo, when Im talking tow cars Im talking auto trans.You can probably tow most any stick shift but how many people are buying stick cars today . A stick in a CRV is a special order. Most people dont know how to drive stickshift. If you leave your radio on while towing you deserve a dead battery.
Old 01-01-2012, 11:11 AM   #20
Install an Axle Lock. Yet another method of adapting a newer car with front drive and automatic transmission for towing four-down is an axle lock. This device is designed to be used on front-wheel drive cars. The axle lock is installed between the transmission and the right front wheel. You simply reach behind the tire and give the unit a twist to either engage or disengage the it.
louis cherry is offline   Reply With Quote
