Old 03-23-2013, 08:02 AM   #11
Great news! What did they do to fix it? Did it have to go to factory or just dealer?
mwebber78 is offline   Reply With Quote
Old 03-24-2013, 09:32 AM   #12
kenandterry's Avatar
There's a number of us wondering just exactly what you mean by "they fixed all four corners."
Have you got any pictures of where the repairs were made, or some more details of what was done to dry things up as far as you're concerned.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 03-24-2013, 04:47 PM   #13
Phat Phrog Stunt Crew
awwall's Avatar
Yes, please, inquiring minds want to know. Good information is great to have if any of us other Georgetown owners have a similar problem.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 03-24-2013, 05:58 PM   #14
jojo bamboo's Avatar
WOW, A happy ending
Its great to hear good news
about Forrest River
jojo bamboo is offline   Reply With Quote
Old 03-25-2013, 03:30 AM   #15
A line slideouts
Chuck692020's Avatar
It could be a marker light but if you rule that out check the seal around the front cap then look at it along the awning rail then the antenna for the radio the channel the wire runs straight from it to the front of the roof under the cap! Check the screws that connect you awning as well because those run into a tube that runs to the front of the roof! If I think of anything else ill post it ! If you have any questions just send me a message! Hope you find your problem!!
Chuck692020 is offline   Reply With Quote
Old 03-26-2013, 08:05 PM   #16
Tim & Lisa Trempert
I'll post some pictures next week.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 04-06-2013, 07:53 PM   #17
Tim & Lisa Trempert
Here are pictures of a couple of the corners where they made the repairs. They used the sealant tape and then caulked all around it so the corners wouldn't come up over time.
ID:	27265   Click image for larger version
Tim & Lisa
2011 Georgetown 350
Old 04-06-2013, 07:56 PM   #18
Tim & Lisa Trempert
Now I have what may be a bigger issue. It looks like I'm getting a crack down the left front side of the RV. I'm not sure how I can fix this without it continuing to come apart. I wonder if there's just too much twisting of the RV and the front cap is failing?
ID:	27267   Click image for larger version
Tim & Lisa
2011 Georgetown 350
Old 04-06-2013, 08:06 PM   #19
A line slideouts
You cap is fin there is putty tape under the black gimp and the crack you see is the seal that is put on each side of this gimp to give it a better look when painted .
Old 04-06-2013, 09:33 PM   #20
Iggy's Avatar
I see these are from the rear cap. Did they do the same on the front cap corners also. I'd like to see the pictures of the front repair as I may do it myself just as a preventive measure. I have the tape already.
Hope you have a few more pictures.
Iggy
