Old 02-19-2014, 12:17 PM   #21
wmtire's Avatar
This whole scenario does have me curious. I'm trying to get my head on this.
I may can understand the converter blowing, and it is hooked to the 120 volt side, but don't see how it could send more than 120 volts to anything else, since that's what it's input is.
I can also understand the surge guard failing, and it letting too much power into the RV, which fried the converter, microwave, etc.
Since it was a motorhome: I'm also wondering if a transfer switch failed, which allowed power at the same time from an inverter and/or generator, and shore power when it came back on after the power outage.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-19-2014, 12:44 PM   #22
Turbs, I'm with ya on this one. I plan the install as soon as we catch a good break in the weather.
Progressive Industries
grayfox is offline   Reply With Quote
Old 02-19-2014, 12:49 PM   #23
TURBS's Avatar
Easy to install, easy to use, lifetime warranty.
Pm sent.
TURBS
Goshen is my playground.
The last man standing also has a sharpie
Old 02-19-2014, 12:53 PM   #24
FYI
Surge Guard Products Warranty
Old 02-19-2014, 12:54 PM   #25
TURBS's Avatar
One year.........
TURBS
Old 02-19-2014, 01:16 PM   #26
fonzie's Avatar
If the Georgetown was hooked up to the 50 amps supply (120/240 volts) and if the converter was the actual culprit in damaging the other appliances, the only way it could happen as far as I'm concerned, would have been a dead short from the live 120 v supply (L1) in the converter to neutral raising the neutral to 120 volts and actually putting 240 volts across the other appliances which are hooked up to the other leg of the supply (L2). Main circuit breakers should trip, but for that instant that it happens, 240 volts could be present......this is a long shot....
Fonzie
Old 02-19-2014, 01:50 PM   #27
CampingDixieDogs's Avatar
Originally Posted by f1100turbo View Post
I dont think this is possible.
By the way spend the money and buy a hardwired progressive industries ems surge.
TURBS
I purchased a SSP-30 because of the recommendations from this board. Hope I never need it, dang glad I have it!
CampingDixieDogs is offline   Reply With Quote
Old 02-21-2014, 01:42 AM   #28
Cornelius's Avatar
Another vote for the Progressive Industries EMS-LCHW50C. The one I installed has detected and prevented problems several times. I would not hook-up without one.
Cornelius is offline   Reply With Quote
Old 02-21-2014, 05:09 AM   #29
cjd10's Avatar
Just getting ready to purchase a surge protector also. Was somewhat on the fence as to which one to purchase but will definitely go with Progressive now.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 02-21-2014, 02:15 PM   #30
Cornelius's Avatar
It is important to note that Progressive Industries make several different products. Among them is the SSP line of surge protectors, and the EMS line. The main difference between the two products is that the SSP models are plugged in at the post, and have test indicators for reverse and open wiring, as well as surge protection.
The EMS products can be plugged in at the post or hardwired inside the RV. In addition to everything the SSP models do, they also test and monitor for high and low voltage, frequency, and protect the air conditioning compressor with a two minute time delay when power is restored. The EMS models have a big internal relay that you can hear connect power to the RV after the device has completed its tests and determined that the power is okay. It will also continue monitoring the power and disconnect using the relay if conditions later change.
At the RV park we are staying at now, when we first hooked-up everything seemed fine. After a couple hours with appliances running, the EMS-LCHW50C shut off the power and gave a low voltage error message. The campground electrician was called and determined that their outlet had internal corrosion. Without the Progressive EMS, we never would known about the damaging low voltage.
There is a lot more than just power surges that can cause problems, so you may wish to consider spending the extra $$$ for the EMS model. It's cheap insurance.
electric, electrical
