Old 02-18-2014, 11:17 PM   #1
Big time electrical issues
Yesterday there was a power outage in the area were we are wintering. When the power came on we waited for the power to come back on as there is always a delay because of the surge protector, it came on after about 3 minutes. It then began flashing on and off probably 10-12 time and went off. When my hubby went to check it there was smoke in the bay where the power comes in. We finally got a RV repair man about 4 hours later only to discover the converter had blown. Today we discover the microwave is fried as well as the washer/dryer. The converter was replaced and after the repair man left this evening we found that something wrong with the LP, you can light the grill outside but no furnace or stove inside. Does anyone have and ideas what is causing this?
krischouinard is offline   Reply With Quote
Old 02-19-2014, 12:29 AM   #2
coupevillefish's Avatar
Check to see if your LP detector is working. It is tied to a selenoid that controls the propane. The outside grill may be tied in before the switch. The LP detector is fused on a separate line, so that fuse could be blown.
2004 Georgetown 326DS
coupevillefish is offline   Reply With Quote
Old 02-19-2014, 05:36 AM   #3
TURBS's Avatar
What kind of surge protector?
TURBS
Goshen is my playground.
The last man standing also has a sharpie
Old 02-19-2014, 05:43 AM   #4
wmtire's Avatar
I am also interested to know what kind of surge protector you had, as it sounds like it didn't do it's job and allowed a power surge to get thru, which is what destroyed your converter and microwave.
How about your television (if equipped), as they also have a habit of getting knocked out when this happens?
Are you referring to the surge protector or the lights in the RV that were flashing on/off?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-19-2014, 07:54 AM   #5
:anim_snoop y:
We did a reset on the LP detector and have propane!!!!
Old 02-19-2014, 07:58 AM   #6
It is a Surge Guard surge protector.
Old 02-19-2014, 08:07 AM   #7
We think the Surge Guard surge protector did it's job as it just let the power through when it was OK, we think the on off on off was from the converter itself.
The only things we have found so far now are the washer/dryer, microwave, and our wifi router. Both TVs, stereo and everything else seem fine.
Old 02-19-2014, 08:09 AM   #8
undr60's Avatar
Call your insurance agent. You might be covered.
undr60 is offline   Reply With Quote
Old 02-19-2014, 08:17 AM   #9
wmtire's Avatar
Then I'm confused. What fried all the appliances and converter? I thought it was an electrical surge, which is what the surge guard is supposed to protect against.
Old 02-19-2014, 08:23 AM   #10
Oakman's Avatar
I think you should replace the surge guard it didn't do its job.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
electric, electrical
