Old 01-24-2016, 03:22 PM   #1
BIRD
Does anyone know where the BIRD is located in a 2000 Georgetown Thanks
terry4106 is offline   Reply With Quote
Old 01-24-2016, 03:26 PM   #2
Probably in a cage. LOL
RCCS is offline   Reply With Quote
Old 01-24-2016, 06:44 PM   #3
Iggy's Avatar
In Terry's pocket.
Old 01-24-2016, 06:54 PM   #4
asquared's Avatar
Please tell us what you mean by BIRD
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 01-24-2016, 07:35 PM   #5
Bi-Directional Isolator Relay
Old 01-24-2016, 07:41 PM   #6
VinceU's Avatar
A "bird" is a short cut for a bidirectional relay device or auto battery charger switch for chassis and coach power supplies for dual simultaneously charging. I doubt a year 2000 had one, became popular maybe 5 years later.
Old 01-24-2016, 08:23 PM   #7
asquared's Avatar
Ok guys, enough with the jokes, please help this new member.
2014 Sabre 34REQS-6
Old 01-24-2016, 09:04 PM   #8
Usually Confused Member
emm-dee's Avatar
I believe the post prior to yours was helpful to the new member. This site is so overloaded with all the abbreviations, etc., that I don't think anyone can understand them all.
I immediately knew what the original post was about because it's a common expression in the aircraft industry (some airplanes can have as many as 4-5 BIRDs, depending on the number of batteries, inverters and TRUs installed). I didn't reply because I don't have a clue what would be installed on the referenced RV.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 01-24-2016, 09:07 PM   #9
asquared's Avatar
Yes Vince was helpful, I'm referring to the joke posts and the deleted posts. The acronym issue was why I had the OP clarify the definition of BIRD.
2014 Sabre 34REQS-6
Old 01-26-2016, 04:33 PM   #10
In my 2004 Georgetown, it is located under the entry steps. Mine looks Like so:Click image for larger version
ID:	98430. (Sure hope the image shows up.)
BigMac8253 is offline   Reply With Quote
