Old 03-24-2016, 10:07 PM   #1
Black Flush is blocked somewhere
Been collecting for 2 weeks now - first thing on the list today once we got setup was to dump the black side. I went to go hook up the black flush and turned on the water, I realized nothing was happening. I have had one these on my other coach so I was expecting to hear water flowing into the Black tank. Nada, zip, zilch on this one.
I curious where the blockage could be? looks like a regular water line that is run from the connection. Wouldn't think it could be kinked but unsure how it routes and terminates into the tank at this time.
Any ideas on what to look for
Thanks in advance.
Mickey Alberto
2016 Forest River Georgetown XL 350TS
Ford V-10 (5-Star Tuned)
cmalberto is offline   Reply With Quote
Old 03-24-2016, 10:13 PM   #2
John McClain's Avatar
the check valve my be installed backwards
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 03-24-2016, 10:17 PM   #3
Where is the check valve at? and how to remove to inspect? Thanks
Mickey Alberto
Old 03-24-2016, 11:25 PM   #4
ramair's Avatar
Our check valve is in the closet of the bedroom where the washer/dryer go.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 03-25-2016, 10:04 AM   #5
I will have to go searching for - will work my way backwards from the Black Tank with the inlet is located...Thanks for the suggestion.
Mickey Alberto
Old 03-25-2016, 10:22 AM   #6
bubbles's Avatar
This is the install in my GT378 and should be similar to yours. The location of the back flow preventer probably changes per model. As previously stated the GT378's location is in the washer/dryer cabinet provision.
Name:	black tank cleanout1.jpg
Old 03-25-2016, 12:23 PM   #7
Boots49's Avatar
Send a message via Skype™ to Boots49
My Wildcat had the flush out valve installed backwards, it had to go back to the dealer who had to cut the piping, reverse the valve & then connect 2 couplers to reattach the pipe. Works great for the last 6 years. If you are still on the warrantee take it back to the dealer.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 03-25-2016, 12:54 PM   #8
This seems to be a very common problem. Take a look at the valve when you locate it for an arrow that shows the flow direction.
Happy RVING! AREN'T TIMES LIKE THIS JUST GREAT!!!
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 03-25-2016, 01:22 PM   #9
Boots49's Avatar
Maybe the factory worker uncharge of installing the back flow valve does not know there is an arrow? Imagine if you can how many Rv's have the same problem. Mine was fixed in 2010. How many before me & how many after mine was corrected?
Al & Susanne
Aka: Puss 'n Boots
Old 03-25-2016, 08:26 PM   #10
Ret. Sheriff.
I had this issue on my Sandpiper. I dropped the underbelly at the holding tank and found a kinked hose. I took the back flush hose off at the tank and took the kink out. Works fine now.
Johnrich is offline   Reply With Quote
black
