12-04-2015, 01:51 PM
New:
Black speckles in clear caulk
I am not sure if anyone else has experienced this, and with the other issues I had with my GT 328ts, I was not willing to start that fight.
But the time may have come. The clear caulk all over the RV has black specks in it. I am not sure if it is mold or stuff that was blowing around the factory when they were caulking mine.
Any suggestions would be great. Should I just grin and live with it, or should I go after warranty?
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
12-04-2015, 02:07 PM
We have the same thing. Suspect mildew.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
12-04-2015, 02:13 PM
Who Dares, Wins
Yeah most likely mildew in the silicone.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
12-04-2015, 02:15 PM
New:
Will they do anything about it?
12-04-2015, 02:20 PM
Have same thing going on with 2012 378 but I put it down to the silicone just general aging, debris etc. Had some success with lightly brushing it with soap , water and soft bristled tooth brush but you have to be mindful not to rip the caulking. 2015 is still pretty new to have it happening already unless there's a lot of miles involved - I wouldn't wait too long to ask them about it.
12-04-2015, 02:52 PM
Who Dares, Wins
Most likely not, they will say does not affect the product, it is aesthetics only.
2015 Chevy HD D-Max
12-04-2015, 02:57 PM
New:
I love that answer when they come up with it.
When you buy a ford, chevy or Chrysler and you find something like that they jump to fix it and you paid 1/3rd what you pay for a coach.
12-04-2015, 03:04 PM
Who Dares, Wins
I agree but rv industry is NOT the auto industry. That is painful obvious in how they act. It's sad.
2015 Chevy HD D-Max
12-05-2015, 02:07 PM
I have the same problem in my 2014 335. Looks like only way to fix it is gently dig old calk out and redo it.
12-05-2015, 02:47 PM
Might be butal (sp) from the caulk.
12-05-2015, 03:28 PM
Who Dares, Wins
Like butyl tape?
2015 Chevy HD D-Max
Test if dirt or mildew
Greetings! Two things can be happening. Mildew happens if the is a food source and wet conditions. You likely have both in the caulk. On the other hand, as elastomeric type caulks such as silicon, expand and contract with temperature it can embed dust and dirt inside the caulking and it becomes impossible to get out. In both cases, it isn't so much a failure of the caulk as it is environmental conditions.
A good test to see if it is dirt or mildew is to take a little bleach on a rag and wipe the area. Wait for a minute, it the stain visibly changes (disappears or turns from black to light brown), then it is mildew. If so, wipe it with bleach and let it dry thoroughly. You're all set. If it is dirt, then enjoy the 'road warrior, experienced' look. The only recourse if to remove the caulk and start over.
Hope that helps. Good camping!
12-05-2015, 03:32 PM
Removal of sealant
Anyone have an easy way to remove the sealant? I was able to remove the horizontal sealant on the passenger side just above the cargo bay, but the drivers side is in solid. Have tried plastic and would scraper. Not easy....
12-05-2015, 03:43 PM
Who Dares, Wins
Mine once started came off in on long solid rubber band.
2015 Chevy HD D-Max
12-06-2015, 03:04 AM
If it is in solid it is adhering well so why remove it?
12-06-2015, 04:08 AM
I cut it with a knife first seems to help brake the seal then scrape the rest off then I hit the area with 3m adhesive remover before I reapply it.
Coachmen M/H
Concord
2018 / 300 DSC
12-06-2015, 09:45 AM
The reason why I want to remove and replace the mildewed sealant is that if it is mildewed. It by definition is permitting moisture to get under it. While it is "adhering" it is also failing.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
12-06-2015, 10:38 AM
what can happen is the installer could use his spit on a finger to wipe the caulk. Bacteria then makes the caulk get black. Not sure of your problem but it is true.
labarn
12-07-2015, 09:25 AM
There are commercial removers by 3M and another (I think Dap). Additionally, there are commercial caulk removing tools that is shaped like a corner. Not easy any way to do it.
