Old 12-17-2013, 05:18 PM   #1
2012 Georgetown 378
raycyn778's Avatar
Black tank Blues!
Hello fellow Georgetownians, need some advice on my 2012 378. Ever since delivery the black tank sensor has read 1/3rd full when empty, sometimes 2/3rds but if I continue to hold the sensor button on it drops back to 1/3rd. Had it into the dealer a few times and so far they have changed out the panel, rewired the sensors at the tank, completely flushed out the tank and who knows what else. Anyone else with this problem and how was it resolved?
thanks all....
Ray, Cynthia, Duncan and Bailey
2012 Georgetown 378
2006 HD Ultra
1992 Fat Boy
raycyn778 is offline   Reply With Quote
Old 12-17-2013, 05:50 PM   #2
Iggy's Avatar
raycyn778
The dumb lights are just probes and that's it. You must have some slime or buildup after the tank was left for awhile in the past.
I have heard some use Calgone Water softener powder and fill up the tank when you are heading out for a long drive tot he campground. Flush a few time.
I have also heard others fill tank with water and add RidX and flush the tank a few times..
Changing sensors and you still may have the same problem. The slime on the tank walls and sensors just need to get cleaned off.
You could also try some dish washing soap that removes grease and add it with lots of water to see if that helps.
Flush, Flush, Flush and hope for the best.
Old 12-17-2013, 06:16 PM   #3
VinceU's Avatar
thanks all....
Another tried and true method is the cleaning lance sold by Camco and Walmart. Insert through head, mark lance at water inlet and direct the jet towards the probes. On Georgetown about mid width of tank top to bottom opposite the head. Train water on probe location and check gauge occasionally. It will soon clear but not for long. I do mine every few weeks to keep cleaned off. Iggy is correct its not really things hanging on the probes, its scum build up on the wall making a circuit between probes.
Old 12-17-2013, 06:28 PM   #4
thanks all....
Or do what most everyone does and that is to ignore the lights until they read full. Both our trailers that came with lights showed 1/3 when brand new and had never had anything in them.
Old 12-17-2013, 08:16 PM   #5
Cornelius's Avatar
Same problem here. The black tank idiot lights are useless. There is an expensive alternative technology that measures the tank density to determine the exact water level. They can be added as an aftermarket item to a tank. Here's an example:
RV Holding Tank Monitor System | ModMyRV
I use a simple and reliable method to determine if the black tank is getting full. When the toilet "burps", it's time to empty the tank...
Cornelius is offline   Reply With Quote
Old 12-17-2013, 11:11 PM   #6
Iggy's Avatar
"When the toilet "burps", it's time to empty the tank"
Old 12-17-2013, 11:14 PM   #7
Iggy's Avatar
Here is another alternatives to your probes.
These suppose to work even with toilet paper on it.
HORST BL232 - Horst Probes, Black Water, 4/pk BL232 - RV Plus
But I like the method.... Wait until it burbs........
Also read this thread on FR Forums with pictures from Lou.
Horst tank Probe Installation
Old 12-17-2013, 11:49 PM   #8
Retired on the weekends
The RB's Avatar
On our last trip, I dumped and rinsed well at the campground, re-filled the tank to about 2/3 full ( I used all the hot water from the HW tank ) and added ( a lot ) of liquid laundry detergent, maybe 6-8 cups or more. During the drive home I made sure to slosh it around and pump the brakes a bit at lower speeds and while approaching stop lights. A hundred miles later, I used the closest rest stop dump station to empty and rinse again. Presto ! Working sensors.
.... But I know it's only temporary.
2008 Sunseeker 3120 DS
CLICK HERE FOR THE PACIFIC NORTHWEST RV GROUP
The RB is offline   Reply With Quote
Old 12-18-2013, 05:20 AM   #9
Oaklevel's Avatar
X2 Very common issue with most RVs black tanks..... I have always ignored the lights & have a real good idea over the years how long we can go before filling the tank.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 12-18-2013, 07:20 AM   #10
TURBS's Avatar
After all the comments about sensors and inaccuracy within them I just have to comment and say that after you've used your unit awhile you'll figure out your tanks capacities and wont even need to use your sensors for reference.
If your a weekender you'll commonly not fill the tanks.
If your a full timer most likely you'll have full hook ups and be able to dump every 3-4 days depending on usage.
Turbs
Sent from my SCH-R530U using Tapatalk
black, black tank, tank
