Old 09-28-2015, 02:23 PM   #1
Retired Ford Tech
Question Black Tank Flush
We are full timers and I never had this issue. I went to back flush the black tank when I was dumping and no water was going through the system.
Way back in March of 2013 the back flow check valve was cracked, so in a pinch, I replace it with an elbow. The system has worked great until now.
I'm about to investigate it but I thought maybe someone might have and thought.
rvpezzano is offline   Reply With Quote
Old 09-28-2015, 04:41 PM   #2
VinceU's Avatar
Sure indicates a plugged nozzle in the in tank sprayer. Maybe fouled by a small piece of rubber hose liner. Most can be removed for maintenance. You should reinstall the vacuum breaker when you do repairs. It may save the public near you from a drinking water contamination.
black, black tank, black tank flush, tank
