Old 06-08-2015, 08:04 PM   #1
dhind's Avatar
Black Water Flush
Perhaps a silly question, but why does the manual require the black water tank valves be open when doing a black water flush. Surely the tank is vented. Is the concern backing up the system through the toilet? I much rather fill it and let it flush out, than just run water through the bottom of the tank.
Not new to motorhomes, but new to our 2015 Georgetown 270.
Dave
dhind is offline   Reply With Quote
Old 06-08-2015, 08:09 PM   #2
Sbryant's Avatar
If you don't open that valve, the back flush water will come out in the bathroom where the vent is.
Sbryant is offline   Reply With Quote
Old 06-08-2015, 08:09 PM   #3
SKnight's Avatar
That's it, the concern is that you don't actually know how full it is. I could fill up, fill the toilet, then even go out the roof vent. Plus, once it's got water in it, the flush isn't flushing anymore, it's just filling with water.
When I dump it if there's not a line I'll flush it with the valve open, once it's running reasonably clear I'll close the black valve, let it flush for several minutes, then will open the valve again. That lets it build up some water, then will purge what's in the corners out.
Old 06-09-2015, 05:58 AM   #4
Tim & Lisa Trempert
Dave
Because you could contaminate the city water supply if the water level got up to the jet spray nozzles. Other reasons too, but this is the primary reason.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 06-09-2015, 06:19 AM   #5
bubbles's Avatar
Dave
You have the right idea for black tank cleanout if it was installed correctly. Just don't start the cleanout and wander off. It takes about 20 minutes for my tank to fill up from the cleanout. I use the indicator and also look directly down the toilet to the tank to know when it is full. You will never have an indicator issue from build up with this procedure. I do use an enzyme additive between dumps. There are a lot of urban legend tales out there concerning the black tank cleanout. The vent is out the roof not in the bathroom. There is no way contaminated water can get in the fresh water system. These are just my input to some of the previous inputs.
Old 06-09-2015, 10:15 PM   #6
dhind's Avatar
Thanks. That exactly what I expected. Just wanted to make sure I didn't miss anything. 20 years of RVi g, but still new information.
Old 07-24-2015, 08:55 PM   #7
I made the mistake of starting my black tank flush with the valve closed and got distracted. The next thing you know I've got water coming out of the toilet onto the floor. After drying up the mess and emptying the tank, subsequently black tank flashings result in water coming out of a pipe under the water heater area. The pipe has a rubber hose slide over it with the end molded in a pinched, but open, position. What could be causing the black tank flush to run out of this pipe even when the black tank valve is open?
Greg_Travels is offline   Reply With Quote
Old 07-24-2015, 09:29 PM   #8
VinceU's Avatar
There is a non-return/vacuum breaker device mounted about 3-4 feet above the tank. Fresh water is routed into the RV, up to the vac break down to the tank flush and sprayed into the tank. Purpose is if shore pressure is lost and the system develops a vacuum, the breaker will prevent the contents of the black tank from being syphoned back into the city water system.
Your problem sounds like a defective vac breaker. Found in closets, in hollow walls. In your case above the dripping compartment. Home repair centers sell them.
Old 07-25-2015, 12:06 PM   #9
Coach 350's Avatar
I agree with Bubbles. I empty it first then empty the grey water tank. At campsites I fill it 1/3 then flush again and again. Never an odor and my sensors are kept clean too.
Coach 350 is offline   Reply With Quote
Old 07-25-2015, 12:40 PM   #10
Islander's Avatar
Greg_Travels ... your post gave me chills down my spine !!!!
I love my Black Water Flush and am thinking of adding some to my 2 gray holding tanks as well.
When I dump I will always top up the black tank with water with the Flush- Sprayer.... fortunately I can hear the spraying water (inside the tank) form outside the RV and when I stop hearing it spray I Open The Dump Valve.
If I am leaving the CG I will fill/rinse the black tank at least once more with the Black Flush Sprayer...and again as soon as I do not hear the 'spray" I pull the dump lever.
This may take some time BUT I NEVER Leave while doing this process....for the very reason you mentioned in your post.
Side note: if you can not hear the spraying water from outside your RV try using a 2ft piece of 1/2" wooden dowel...round off one end and place the round end to your ear (at the position between your temple and outside your ear) and the other end near the vicinity of the back tank or buy a cheap stethoscope .
hope this helps
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
black, black water, water
