Old 05-03-2013, 03:15 PM   #21
bubbles's Avatar
I too got a replacement valve from the manufacturer (no charge/free shipping) due to a hairline crack. My valve is not like YOUROO's and I think it is rated at 200psi. I did bypass it though when I did my blow out. I guess I just got lucky that the blow out cleared the nozzle.
Old 05-03-2013, 08:24 PM   #22
Problem Solved!!!
Originally Posted by fbconsults View Post
When I try to introduce water into the black water holding tank through the black water flush system, it seems to be plugged somewhere. My first thought was the anti backflush valve where the external water hose attaches was stuck, but when I depressed the valve, water squirted out. I assume this was from the backpressure in the line. I wonder if threre is another anti backflush valve somewhere. It doesn't seem like just "stuff" where the water sprays into the tank could create this problem.
Any ideas?
Thanks, Forrest
I hooked the air tank up to the black water flush inlet, turned on the air and Viola! I heard the clog come loose and the line was clear. Hooked up the water and I can now hear the sprayer working.
I hooked the air to water line adapter which is normally used to clear water from the lines when you winterize. Had about 75lbs of pressure in the tank, and turned it on. What a relief!
The adapter is available at Camping World or your camping accessories store for less than ten bucks if you don't have one. I should have thought of it before.
Thanks for all the suggestions and ideas, I appreciate it. All of the comments cause you to put on the old thinking cap.
Happy Trails (And clean black water tanks, LOL),
Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 05-06-2013, 09:13 AM   #23
How do get to the black tank flush input,mine is leaking when i flush,it is a 2012 378xl.Do you have to take the panel off at the water heater.
manvel is offline   Reply With Quote
Old 05-06-2013, 09:44 AM   #24
Iggy's Avatar
Yes it is located in the hot water compartment upper right hand corner.
It is a blue waterline to a 90 degree elbow that goes into tanka nd sprays.
Old 05-06-2013, 03:34 PM   #25
Thanks,after finding it,found the water was coming from the hose on the bottom of the one way valve and running down the hose. Got the leak stop for now with tape,out on a trip,will fix better when i get home.
Old 06-29-2014, 04:17 PM   #26
WisconsinCowboy
ejaeger's Avatar
Do you have to take the hot water tank and or face off?
ejaeger is offline   Reply With Quote
Old 06-29-2014, 04:18 PM   #27
WisconsinCowboy
ejaeger's Avatar
We have a 2014 352XL that water pours out of the hot water tank compartment when I try and flush the black tank.
Old 06-29-2014, 04:57 PM   #28
Herk7769's Avatar
Yes, you will get your shoes wet
ID:	56693   Click image for larger version
ID:	56694   Click image for larger version
ID:	56695   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 06-29-2014, 05:08 PM   #29
Ford Idaho's Avatar
With my Atwood I will loosen the plastic plug till I can turn it with my fingers.
Once it is loose I stand off to one side and reach as far as I can to take it out and then flip the pressure relief valve.
Old 06-29-2014, 05:13 PM   #30
WisconsinCowboy
ejaeger's Avatar
I guess I'm not understanding. .. my leak is coming from inside the compartment that holds the hot water tank. There is no way I can see to get to it unless you physically pull out the hot water tank.
