03-01-2016, 11:02 AM
Black water flush waterline leak-I have a leak near the top of the water heat...
I have a 2008 GeorgetownXL 359.
Is there another access point to get to the lines in addition to the 5 in hole near the water heater?
Thanks.
03-01-2016, 04:09 PM
Mine broke @ the elbow going into tank I had to take it in I did not see how they got to it though
2014 Georgetown XL 378
03-01-2016, 04:10 PM
One time before it leaked & it was the check valve was cracked
03-01-2016, 04:37 PM
Thanks. I have a repair guy coming tomorrow. I'll let u know what he suggests.
08 Georgetown XL
03-02-2016, 04:30 PM
cler-b
I have a 378 XL, the Nozzle going in to the Black tank was broken when
install and I also found black putty in the nozzle and the leak on top of the
hot water heater and the water was dripping in that 5 inch hole,
so lift the side panel door and you have the HWT plus you will see were
the Water is dripping, the panel at the bottom you will see 2 L shape
braket with 2 screw each
03-03-2016, 05:34 PM
Hmmm. I don't think I have those brackets. My repair was delayed and I've been called out of town. I should be back early next week and I'll see if I can get a pic of my access area.
Thanks for the info.
03-03-2016, 09:12 PM
X2( in the bathroom under the sink.)
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
03-04-2016, 02:07 PM
Thanks, I'll check that out.
03-09-2016, 11:56 AM
Cler-b
Located the L brackets. Friday is repair day.
Thanks for the help. I'll let u know how it turns it.
03-10-2016, 01:36 PM
Found the pesky leak. It was the check valve for the black water flush. Valve was cracked. Will get new one and be good to go.
Valve was located on the side wall above the water heater. We got to it by removing the drawers under the pantry in the galley. Could have been worse.
Thanks for your help.
Travel safe.
03-12-2016, 11:48 PM
I think that check valve holds water on one side of it when you flush out the black tank. I now make sure I blow the line out when winterizing.
2003 Dodge Dakota
Hampton Roads VA
03-13-2016, 06:38 AM
Yep, I blow my lines out also but not this one. You can be sure I will now.
Thanks again.
03-13-2016, 07:03 AM
You couldn't have hoped for anything easier to fix.
Bruce
03-13-2016, 07:16 AM
They do make a metal one I put this one on last time I have had 2 plastic ones break
Cash Acme 17383-0000 V-101 1/2-Inch Brass Anti-Siphon Vacuum Breaker https://www.amazon.com/dp/B000MNLNF6..._3Lv5wb2PBZHDG
03-13-2016, 07:30 AM
It is an easy fix. I just wish I had longer arms.
03-13-2016, 08:36 AM
Thanks for the tip on the brass valve. I see an Amazon order in my future.
