Old 03-01-2016, 10:02 AM   #1
Black water flush waterline leak-I have a leak near the top of the water heat...
I have a 2008 GeorgetownXL 359.
Is there another access point to get to the lines in addition to the 5 in hole near the water heater?
Thanks.
Pkowski is offline   Reply With Quote
Old 03-01-2016, 03:09 PM   #2
Mine broke @ the elbow going into tank I had to take it in I did not see how they got to it though
2014 Georgetown XL 378
kgreen is offline   Reply With Quote
Old 03-01-2016, 03:10 PM   #3
One time before it leaked & it was the check valve was cracked
Old 03-01-2016, 03:37 PM   #4
Thanks. I have a repair guy coming tomorrow. I'll let u know what he suggests.
08 Georgetown XL
Old 03-02-2016, 03:30 PM   #5
cler-b
I have a 378 XL, the Nozzle going in to the Black tank was broken when
install and I also found black putty in the nozzle and the leak on top of the
hot water heater and the water was dripping in that 5 inch hole,
so lift the side panel door and you have the HWT plus you will see were
the Water is dripping, the panel at the bottom you will see 2 L shape
braket with 2 screw each
cler-b is offline   Reply With Quote
Old 03-03-2016, 04:34 PM   #6
Hmmm. I don't think I have those brackets. My repair was delayed and I've been called out of town. I should be back early next week and I'll see if I can get a pic of my access area.
Thanks for the info.
Old 03-03-2016, 08:12 PM   #7
X2( in the bathroom under the sink.)
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
Old 03-04-2016, 01:07 PM   #8
Thanks, I'll check that out.
Old 03-09-2016, 10:56 AM   #9
Cler-b
Located the L brackets. Friday is repair day.
Thanks for the help. I'll let u know how it turns it.
Old 03-10-2016, 12:36 PM   #10
Found the pesky leak. It was the check valve for the black water flush. Valve was cracked. Will get new one and be good to go.
Valve was located on the side wall above the water heater. We got to it by removing the drawers under the pantry in the galley. Could have been worse.
Thanks for your help.
Travel safe.
black, black water, heater, leak, water, water heater
