Old 02-08-2015, 05:53 PM   #1
Blackwater Flush problems
I have a 2014 351DS. I recently had the dealer fix my blackwater flush line under warrantee. The dealer said that the line was installed wrong. I never double checked the fix and just recently went to use the system. Instead of the water running into the blackwater tank I get clean water spewing out from above the blackwater tank in an area that is inaccessible above the hotwater heater. Of course my warrantee is now over as of a week ago or so. I am not sure what is wrong. Has anyone else had this problem.
Preadus is offline   Reply With Quote
Old 02-08-2015, 06:09 PM   #2
Ford Idaho's Avatar
Because this reads like it is a failed warranty repair you are still covered because you opened the claim while it was covered, hardly your fault the dealer did it wrong.
Push them on it.
Old 02-08-2015, 06:13 PM   #3
cjd10's Avatar
I have the same problem with mine. When I took it in for a few other things including that, the dealer told me they would have to take out the refridgerator and stove and cut a hole in the floor to fix it. I told them I thought there should be a better way without cutting up my MH as I had read of others with that problem. They told me since it had been listed as a problem before the one year warranty ran out they would take care of it the next time I was in.
I contacted Kevin at FR and he told me to have them call him and he would connect them to someone who could tell them the correct procedure to fix it.
I haven't been back in to get it taken care of yet but it seems as if yours was an was an issue before the warranty ran out they should go ahead and fix it.
If not I would contact FR and discuss it with them as the black water flush leaking is a known issue.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
Old 02-08-2015, 07:00 PM   #4
Wonder if the leak could be the result of a faulty vacuum breaker valve or related connection?
I had a similar problem, and found that the vacuum breaker valve output tube had cracked and separate at the 90 degree output fitting.
My valve is located behind the shower surround right behind the circular access cover under the diverter.
Just a thought - good luck.
livingouradventure is offline   Reply With Quote
Old 02-08-2015, 08:39 PM   #5
I had the same thing happen there was crack in the flush line they replaced the section with a flex line instead of pic I haven't used it yet they got the fix from forest river Kevin Stratton they pulled out the water heater to fix I'm going to use the camper in March I hope everything works if not Kevin will be getting a call
Grouch1
2013 Georgetown 351dsf
2011 Jeep Wrangler
Grouch1 is offline   Reply With Quote
Old 02-08-2015, 08:41 PM   #6
Thanks for the info everyone. Looks like it is something I am not interested in fixing myself, so I will have to definitely get with my dealer to get it done under warrantee hopefully.
Old 02-08-2015, 08:43 PM   #7
GABoy's Avatar
Our 2014 351 is in for warranty repair on same problem. When using black tank flush clean water runs from over water heater into compartment with inverter. My understanding is its leaking on side of black tank where water line connection is going into it. I think they removed the water heater outside shield to get to it. The vacuum breaker leaked earlier and I had FR send me a new one. But it leaked inside under sink cabinets. The breaker is located behind the drawer beside stove. I've been told they have fixed it. I will be sure to give it a try when get home.
Chevy Colorado Crew
GABoy is offline   Reply With Quote
black, water
