Old 09-03-2012, 03:12 PM   #11
Send a message via Skype™ to Falcon35
If you look under the hood on the driver side ( on the right is you look in ) there is a wire harness marked for the different lights and a wire attached to vertical frame member. It seems to me that is where we need to start. When it comes to things like this I only enough to be dangerous. I'm going to take it to mechanic that I trust to check it out for me.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 09-05-2012, 01:18 PM   #12
I COULD NOT BELIEVE THIS.
We replaced the bulb for the right front signal light and the signal works and the camera's and display work even when the lights are on. Everything is back as it should be.
It seems the bulb must have been shorting out the camera system.
2008 Honda Fit
Protect-A-Tow
