Old 06-29-2010, 03:02 PM   #1
ggm
blockage in sinks
hiya
can anyone help please, had issues this weekend with blockage in both sinks and the sink in the toliet, could not clear with sink plonger, had to remove the dump valves. tanks is not full?
it seem to be backing up in the toilet?
ggm is offline   Reply With Quote
Old 06-29-2010, 03:07 PM   #2
ggm
Its should read backing up in the sink in the toilet.
one thing i did find out was there was pipe which connects to the sink with a screw top with two small holes, opened this and cleared blockage?????
Old 06-30-2010, 12:44 PM   #3
ggm
Any help would be appericated, someone must have a few ideas
graham
Old 06-30-2010, 01:15 PM   #4
So its backing up in the sink and in the toilet?
Nights Camped 2011- 12
blake2727 is offline   Reply With Quote
Old 06-30-2010, 01:55 PM   #5
milzat's Avatar
I think he means, the sink(lavatory) in the Toilet Room.
milzat is offline   Reply With Quote
Old 06-30-2010, 01:58 PM   #6
milzat's Avatar
All sinks are most likely plumbed to the same Grey water tank. If so, I'd say there may be a blockage, where the drain piping is connected to the Grey water tank.
Old 06-30-2010, 02:42 PM   #7
If the tank is not full then it has to be one of the lines stopped up thats going to it. Check the trap first since it will probably be the easiest thing to get to. Thanks for explaining milzat because I was totally confused.
Old 06-30-2010, 03:30 PM   #8
Sink Blockage
The problem is the down pipe going into the gray tank has been pushed too far down into the tank. There is no space between the end of the pipe and the bottom of the tank. The fix is to access the 2 down pipes and lift up and cut off the excess pipe. The last FR I did, the down pipes were on the Road and Curb side. Doug
DOUGRAINER is offline   Reply With Quote
Old 06-30-2010, 04:40 PM   #9
ggm
I removed the front cover into the gray tank, The front cover is about 4 inches round, this then goes into the waste pipe outlet. no real water came from this.
I will try and remove the u trap on the sink in the toilet.
does anyone wash out their tanks?
Old 06-30-2010, 05:55 PM   #10
milzat's Avatar
Yes, I think most owners do. I always flush out the holding tanks after every trip.
