Old 02-05-2014, 10:59 AM   #1
raoulwv's Avatar
Blue Ox Alpha or RM Falcon 2
Hi all,
I just bought a new toad and after 12 years of use, have decided to get a new towbar as well. It's down to a Blue Ox Alpha or Roadmaster Falcon 2. Does anyone own one of these, and if so, can you give some feedback pro or con?
Rod & Carla B.
The Hounds Kooper & Abby
2015 Sunseeker 3010; '14 Ford Focus toad
raoulwv is offline   Reply With Quote
Old 02-05-2014, 03:53 PM   #2
I don't know about the others but I just bought road master I like it real easy to use
kgreen is offline   Reply With Quote
Old 02-05-2014, 04:58 PM   #3
got a stowmaster//roadmaster easy and easy and also easy to use
rwehba is offline   Reply With Quote
Old 02-11-2014, 11:35 AM   #4
ramair's Avatar
have the stow master for our cruze and real easy to connect and dis-connect. Had no issues. would highly recommend it.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 02-11-2014, 12:07 PM   #5
silver's Avatar
I have the Falcon 2 for over 5 years. Pull my Grand Cherokee at least 35000 miles now with no issues. I look it over before each trip and keep it clean. Other than that just use it.
silver is offline   Reply With Quote
Old 02-11-2014, 12:08 PM   #6
Iggy's Avatar
Originally Posted by raoulwv View Post
Hi all,
What is the weight of your new toad?
I picked up a Roadmaster Sterling All Terrain on Craigslist with all the accessories and the Roadmaster rockguard for $550.
It is designed for 6,000 lbs but it is great for any angles or inclines and is easier to connect and disconnect.
Look around Craigslist and see if you can save a lot of money.
Old 02-12-2014, 12:14 PM   #7
raoulwv's Avatar
Thanks for your responses. I've decided to go with the Blue Ox, simply because I'm getting a Blue Ox mounting bracket. The Blue Ox bracket is one piece, as opposed to the Roadmaster, which is a two piece and requires the use of a crossbar with your towbar. With the Blue Ox, a crossbar isn't needed(one less step for hooking up).
P.S. My toad is a Ford Focus(about 3k lbs.)
Rod & Carla B.
blue ox
