Old 09-07-2014, 08:28 PM   #11
Iggy's Avatar
Here is a picture of my 2012 378 rubber under slide.
Hope this helps a little in identifying what should be there.
Iggy is online now   Reply With Quote
Old 09-07-2014, 08:33 PM   #12
Thanks Iggy.. Yours looks like it's held on with a bracket ( is your a hydraulic slide ?) I have similar recess ( mine is cable driven with rollers) looks like mine was glued on ..
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 09-14-2014, 07:37 PM   #13
cjd10's Avatar
Originally Posted by speedjester View Post
Sorry no pics.. But bottom of slide behind rollers . Looks like something was glued there that wiped / sealed upward against bottom of slide.. You would need a a light to look in that area ..
While re-attaching the wipers on the front slide I remembered reading this post and looked closer on the bottom of the slide. There is a wiper further in behind the rollers on mine. Don't know how I could ever get to it to wipe with silicone spray but there is one in there I had never noticed. Didn't know exactly where you were trying to describe until re-reading your post just now. Will try to get a pic for you but might be difficult due to the location. Will also check the back slide.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 09-14-2014, 07:56 PM   #14
Cjd10.. If you could snap a few pics for me it would be really appreciated...trying to figure out what keeps it from rolling in when retracting slide.... Thanks again..
Old 09-15-2014, 08:48 AM   #15
GABoy's Avatar
I tried to take a pic of my wiper seal after reading these post. As CJ says mine is located behind the rollers towards interior if coach. Hope this helps.
Name:	ImageUploadedByForest River Forums1410788919.660988.jpg
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 09-15-2014, 08:57 AM   #16
Thanks For the pic ..
Hard to see but Looks like it's right up against the rear bulkhead and the seal lip itself is just laid flat against bottom of slide.. Am I correct ?? What keeps it from getting pulled the other way when you close it? .. Seems I always have to unjam a seal either on the outside or inside ...( part of seal gets pulled in when closing and stays that way when opened )..
Old 09-15-2014, 09:13 AM   #17
GABoy's Avatar
I believe it's attached on the interior side of the lower outside wall. As slide goes in or out the seal lays to that particular direction. If slide wasn't there seal would stand straight up, vertical. I guess they moved it at some time from exterior to interior in same wall during newer model years.
Chevy Colorado Crew
