Old 07-27-2016, 06:36 PM   #1
WhoDoMan
Brake fluid
Quick question on 2014 Georgetown 377 brake fluid. I found a forum that lists a Dot 4 fluid. Anyone have a different opinion. Thanks!
whoDoMan is offline   Reply With Quote
Old 07-27-2016, 06:42 PM   #2
What does the owners manual say? If you have the F-53 chassis it should be Super DOT 4 per Ford.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 07-27-2016, 06:52 PM   #3
Most everything uses DOT4, pretty much standard. Some older stuff may say DOT3.
Change it out at least every two years and better to flush with new fluid once a year.
Moisture builds up in the fluid (it is made to absorb fluid) and then corrosion starts to do it's work.
MtBiker is offline   Reply With Quote
Old 07-27-2016, 07:02 PM   #4
WhoDoMan
Thanks.... If I had gotten a manual I'd consult it. It seems they forgot mine and I've never been able to get a copy. I'll use the Dot 4 thanks.
Old 07-27-2016, 07:08 PM   #5
Double check with the auto parts store just to be sure.
