Old 06-11-2015, 06:07 PM   #1
broke down at the inlaws
my rv did not seem level so i turned it on to check the level. when i turned on the leveling system all the warning lights came on and it will not work. of course the jacks are down and i am in the drive way. any help would be greatly appreciated. does anyone know of a mobile rv repair in Jefferson city Missouri
ndb767 is offline   Reply With Quote
Old 06-11-2015, 06:11 PM   #2
Flybob's Avatar
Is it plugged in to shore power, if not the battery may be low. If no shore power available, connect to TV and turn on TV
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-11-2015, 06:34 PM   #3
TURBS's Avatar
It's a motor home
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-11-2015, 07:33 PM   #4
I had a problem two weeks ago with my Bigfoot system. Mine would not retract and I had an "all up" light lit. Nothing I did would work. I called Bigfoot and talked to someone named Jim on a Sunday morning. He was very helpful and worked with me. We first unplugged the remote wire harness to "reset" the chip. That didn't work and ultimately unplugged and plugged in the full wire harness in the back of the main box under the seat. It ended up that the main wire harness had come out a slight amount. After plugging the harness everything worked perfectly.
I really appreciated Bigfoots 24/7 customer service. Good luck.
Gilm2113 is offline   Reply With Quote
Old 06-11-2015, 07:37 PM   #5
LittlePM's Avatar
You don't say what kind of RV you have. We had a problem with our motor homes leveling system and slides two weeks ago, I call my dealer for help, they told me to reset the breakers by the batteries, after that everything worked great.
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 06-11-2015, 10:47 PM   #6
Iggy's Avatar
The bad part is it broke down at the in-laws location.
Seriously, if all the lights are flashing you need to reset the system.
Please read the manual I have attached. It looks like it is in the Latch Out Mode.
Old 06-11-2015, 11:07 PM   #7
I know.. I was just thinking, "man y'all are so nice". Fella in a situation like that you might be able to get him to go as high as 2 cases of beer and a pack of steaks to get him runnin again.
That would be my approach as well. "Hard" reset the system.. check wire harnesses while disconnected from all power. Even if they appear to be fully plugged in, there may be a small bit of oxidation that could be affecting a connection. Just removing the harness and plugging it back in may rectify that.
rana is offline   Reply With Quote
Old 06-12-2015, 01:02 PM   #8
mike.t's Avatar
I knew you shouldn't have married him. If you had married (fill in blank) he would have bought you a nicer/bigger/fancier/more expensive what ever that thing is.;o)
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 06-12-2015, 09:53 PM   #9
The manual extend/retract procedure in this manual is great for systems with a reversing motor. My 2011 Georgetown 327DS has a unidirectional motor/pump system which includes an additional control on the hydraulic manifold to control where the high pressure fluid is sent; to the top or the bottom of the jacks. Unfortunately, my system has had issues where a diode in the wiring harness gets fried and locks the control system in extend mode. With the system set in extend mode, the only way to retract the jacks is to drain the hydraulic fluid from the system.
Fortunately, the default position of the hydraulic control system is to retract the jacks. The control unit can be forced into this mode by disconnecting power to the solenoid that switches it into extend mode. This solenoid is located on the left side of the hydraulic control unit, below the quick flush connector.
Lippert has a replacement wiring harness for these units that resolves this problem. I burned out two harnesses before the revised one was available.
If your hydraulic control fails with this problem, your RV will rise up when you try to retract the jacks. If you notice this happening, hit the "off" button on the jack control panel or shut off the engine. Disconnect the solenoid then the jacks will retract normally. If you need to extend them again before getting them repaired, reconnect the solenoid and manually level the coach remembering that you can't retract the jacks until you unplug the solenoid again. The automatic levelling mode of operation will not work when the solenoid isn't functioning properly.
Phil
pmsherman is offline   Reply With Quote
Old 06-12-2015, 10:53 PM   #10
accumack's Avatar
You may want to pull the control panel and make sure no wires have pulled out. We have the equalizer system and the leveling acted funky I pulled the panel and found someone had just pushed the wire into the plug after I repaired it no more problems. I don't know if you have the same system or not our unit is a Berkshire. I assume yours is a Georgetown.
accumack is offline   Reply With Quote
