Old 03-27-2015, 07:34 AM   #1
Starboard's Avatar
Broken key to compartment
2015 GT 351DS. Went to open the passenger side rear most compartment and the key simply broke off inside the keyhole of the slam latch. Now it's stuck inside. What are my options?
Take it to a locksmith after taking the whole assembly out or do I just replace the assembly?
I looked and it wasn't obvious to me that the lock tumbler can be removed... Any ideas?
Starboard is offline   Reply With Quote
Old 03-27-2015, 08:00 AM   #2
If you get to the point where you are considering just replacing the latch, you could try some super/crazy glue. Just use it very sparingly so as to not get glue all over the insides.
Filthy Beast is offline   Reply With Quote
Old 03-27-2015, 08:09 AM   #3
First,is the compartment open? so you can get to the lock assembly, if so just remove lock cylinder and place with new ( you may have different key if you can't get same code number) second, if in closed locked position you could drill out lock,turn open with screwdriver, then open compartment and remove lock assembly and replace.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-27-2015, 08:28 AM   #4
mark0224's Avatar
My understanding from my dealer and readings on line and here all compartment locks use the same key unless you change them and specify that they are coded different. In your case if you can get the lock out take it and tap it on a counter then using a small pair if needle nose you should be able to get a hold in the piece of key and pull it out. If it is locked some compartments are accessible from inside the trailer check that before drilling the lock out as has been stated earlier. If you can get to it from inside the trailer just unscrew the center screw and it will be unlocked. I changed all my compartment locks and had the new ones keyed to be the same as the door key. A company called rvlocksandmore.com had them cheapest .
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 03-27-2015, 08:37 AM   #5
PhoneDude 8289's Avatar
I have used a coping say blade. You will have to break off the end of the blade that holds it to the saw frame. Slide the blade in on the flat side of the key, 90% from the keys teeth. Turn the saw blade slightly so the teeth of the blade grab the key and gently extract the broken key. May need to use two pieces of the saw blade, one either side of the key. Worked for me.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 03-27-2015, 08:37 AM   #6
R&J Silverback's Avatar
myself I would call a good locksmith. he can get old key out without drilling a make you a new key.
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 03-27-2015, 08:45 AM   #7
Flybob's Avatar
If the compartment is a pass thru, and the lock is locked you can go in thru other side and remove lock, Once removed, you can tap the lock or use a surgeons clamp to remove the broken key. There are only a few key sets that are used in most RVs. You can order another key at most RV centers and even online if you have the key number, CH751 is the most common.Replacement Key for Compartment Hardware - RV Designer L200 - Compartment and Hatch Hardware - Camping World
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-27-2015, 10:34 AM   #8
WDK
WDK's Avatar
I am for spending a little more money and just drive it to a lock smith....he can get the key out, make you a new one with no damage to your lock or mechanism....should not take a good smith no more than 30 minutes.....$29.99.....
WDK
WDK is offline   Reply With Quote
Old 03-27-2015, 12:02 PM   #9
There is a tool for that. Broken Key Extractor. It's a very fine saw blade. Google, broken key extractor. Amazon and others offer it. I've used mine a few times. Pays for itself quick.
Wallace
twiggw is offline   Reply With Quote
Old 03-27-2015, 12:25 PM   #10
Starboard's Avatar
Great, thanks everyone for quick replies! I fixed it -
Carefully removed the entire lock assembly by unscrewing the 4 screws.
Once inside the house, I used a thin metal pick to just work the little key stub out of the keyhole, being careful not to put too much pressure on the lock or pick so not to break it. The broken key actually came out!
I then liberally oiled the entire lock, and oiled it again - it now works smoothly.
I am down to one key for my compartments, so tomorrow I will go to the local lock store to get a few extras made.
Phew, thought I was in for some $$$ spending to get this fixed!
