I'm considering buying this 3 gal 110 psi oil lubed air compressor from Home Depot.
I will keep it in one of the compartments for use to maintain tire pressure up to 110 psi.
Does anyone have one already?
Do you know a better one with the similiar size and price?
Husky L13HPD from Home Depot $99
Husky 3-gal. compressor features a 1 HP induction motor with oil-lube operation. This air compressor has a direct-drive pump for convenience and an oil sight glass that makes it easy to check the oil level for safe operation. This air compressor has an aluminum tank for a long life.
- 1 HP induction motor with oil-lube operation
- Direct-drive pump has no belts or pulleys to replace for convenience
- Single-hand operation for convenience
- Quick connect helps you quickly change applications
- Oil sight glass makes it easy to check the oil level at a glance for safety
- Dedicated tank and tool regulator gauges for convenience
- Colors may vary
- 9-piece accessory kit includes blow gun, OSHA safety nozzle, blow gun adapter, 1/4 in. female quick connect, 1/4 in. male plug, 1/4 in. female plug, inflation needle, 6 in. dual tire chuck, and sealing tape
- MFG Brand Name : Husky
- MFG Model # : L13HPD
- MFG Part # : L13HPD
